Lost waterfall
bjn644 .
Turned on my 6400 with v3.0.27 today and no waterfall. The upper panadapter part works but not the lower waterfall. I can click on the lower left button to turn on another panadapter and the waterfall in that works, but not the primary one. I have re-booted the radio and PC a couple times and no luck.
Have turned off the radio and power off the power supply? The full power off will sometime clear up the odd issues.
Just tried that, no luck.0
Could it be your display settings? Do they differ from the panadapter with the waterfall showing?0
Problem found
Under the display tab, the "Black" button magically was set to 0 and Auto turned off. Turning auto back on fixed everything.
Thanks to all.
730 -
You're welcome!0
Had this problem on my Maestro. This fixed it. I was at my wits end trying to figure why my waterfall on Slice A had disappeared. Still had one on Slice B. Thanks so much. Really appreciate your post! 73 de Carl N8VZ
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
