SmartSDR sees Flex 6300 but is unable to connect
Santiago Mejia HI8O
I just received my Flex 6300 and installed SmartSDR latest version (2.5.1.130) and everything else. When I run SmartSDR, I see the radio as Available but when I click connect nothing happens for a few seconds then I get "unable to connect to radio", and other times I get the same version but the right side of the Monitor goes black.
I'm running Windows &7, with 8GB RAM, 3.10ghz processor. Tried connecting ethernet cable directly to computer and still same issue. Tried on an older laptop, same issue.
Anything you can advise a newbie?
73 de Santiago HI8SMX
A couple of possibilities come to mind. 1.Be sure you are not trying to connect locally with SmartLink - that won’t work, it’s intended for WAN use. 2. Are there any firewall rules active? The discovery traffic that causes the radio to appear is broadcast UDP, and once you talk to the radio, you are using unicast TCP (I.e. setting up a bidirectional connection to the radio). That’s a start anyway.2
Maybe the previous owners configuration is still in the radio? If so, try doing a reset to restore the default settings. The default settings are a good starting point.1
Thanks Ted and Paul, indeed si verified the items you mentioned and everything seemed Ok. I did managed to make it work by unplugging the power from the radio and plugging it again. Go figure!!! Please bear with me as all this is still new to me. Now on to the next steps.0
That makes sense, as there are parts of the radio that are not fully re-initialized until power is removed. The power switch is really mostly a soft power-off.0
- 335 Community Topics
- 601 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 171 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 880 Genius Products
- 318 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 731 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
