flex5000a Keyline issue help
Flex5000A radio and clean install with power sdr 2.8.0.130. Problem is the amp relay jack tx1,tx2 or tx3 when activated does not shunt to ground. I also measured when the ppt closed a.6 Volt on the active tx1,2,3, rca port. Zero volts when ptt is not keyed.  I have tried 2 different flex5000a radios with same result. Trying to figure out if it is software,firmware, or bad darling-ton pair transistor in both radios. Also is their some kind of work around to activate the RF amplifier key line.
  • David Umbaugh
    David Umbaugh Member
    edited July 2019
    Call me to discuss. I think I had the same problem a couple years ago. 330-283-1914
  • Tom Martin
    Tom Martin Member
    edited July 2019
    I use a Ameritron ABR-704 with DDUtil ver 3.2.6.00
    Hopefully this is what might help you. It keys my ALS1306 just fine
    Tom Martin W7TJM
  • Fred Friedl
    Fred Friedl Member
    edited July 2019
    Under "ANT" on the top bar of the PowerSDR software, do you have one of the switch relays checked off?
    Fred - WX4US
  • Rich Ferguson
    Rich Ferguson Member
    edited July 2019
    I have all 3 checked the only change when ptt closes is .6 volt on connector when ptt is closed.
  • Dudley  WA5QPZ
    Dudley WA5QPZ Member ✭✭✭
    edited March 2020
    Rich, The TX1-3 outputs are open collector, and need a positive voltage applied before seeing a change on a meter. In other words, there is no pull up voltage on the outputs. You can apply a less than 50 volt , current limited DC voltage and should drop to roughly .6 volt dc but less than 100 ma. DO NOT connect a cathode keying circuit to the TX outputs as it will wipe out the keying chip. 73, Dudley WA5QPZ
