flex5000a Keyline issue help
Rich Ferguson
Flex5000A radio and clean install with power sdr 2.8.0.130. Problem is the amp relay jack tx1,tx2 or tx3 when activated does not shunt to ground. I also measured when the ppt closed a.6 Volt on the active tx1,2,3, rca port. Zero volts when ptt is not keyed. I have tried 2 different flex5000a radios with same result. Trying to figure out if it is software,firmware, or bad darling-ton pair transistor in both radios. Also is their some kind of work around to activate the RF amplifier key line.
Call me to discuss. I think I had the same problem a couple years ago. 330-283-19140
I use a Ameritron ABR-704 with DDUtil ver 3.2.6.00
Hopefully this is what might help you. It keys my ALS1306 just fine
Tom Martin W7TJM0 -
Under "ANT" on the top bar of the PowerSDR software, do you have one of the switch relays checked off?
Fred - WX4US
I have all 3 checked the only change when ptt closes is .6 volt on connector when ptt is closed.0
Rich, The TX1-3 outputs are open collector, and need a positive voltage applied before seeing a change on a meter. In other words, there is no pull up voltage on the outputs. You can apply a less than 50 volt , current limited DC voltage and should drop to roughly .6 volt dc but less than 100 ma. DO NOT connect a cathode keying circuit to the TX outputs as it will wipe out the keying chip. 73, Dudley WA5QPZ0
- 334 Community Topics
- 601 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 170 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 880 Genius Products
- 318 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 731 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
