Stability Issue with Flex 6400M + Slice Master + DM780 + Win10
Helmut Spahn
Helmut Spahn Member
edited July 2019 in SmartSDR for Windows
I configured Flex6400M, Slice Master, DM780 and WIN10 as of SW recommendations. I'm running SW for all tools / devices with latest version.
After System Startup it works as expected (eg. PSK31) for approximately 5 minutes.
Then system crashs . . .
To bring it back to live requires restart of Flex6400M, Win10 Laptop, Slice Master / DM780.
After some minutes - same issue again, and again, . . .
Any idea really appreciated - did someone experience similar challenges ?
Helmut, DJ5KR
  • Joe N3HEE
    Joe N3HEE Member ✭✭
    edited July 2019
    Have you had this configuration working before now ?  Or is this a new configuration ?  This could  be a memory problem.  Run a memory checker such as MemTest 86 or similar.  I had system crashes caused by a bad memory.  Also check Windows event logs for clues.
