Firewire connection. I'm stumped.
Mark Gottlieb
This my 3rd Flex 3000 over the last 5 years so I think or, at least, I thought I knew this radio. Anyway, first of all, I see the green reflection around the FW connection in the back of the radio when it is powered on indicating FW switch is operational. All was fine until this past Friday when I attempted to start the radio and got the "No devices found" message. At first, I thought it was the FW card gone bad. I purchased a new FW card from Amazon and got the same result. I tried my spare FW cable and received the same result. I then attempted to connect to my two other computers and the same result. Two of the computers are Win10 and one is Win7 all with the same result. Blue light is on in the front of the radio and I do hear the relay click when it is powering up. I'm stumped. Any suggestions?
Mark
KK2L
Mark
KK2L
Mark
The most sensitive part in the radio (IMHO) is the firewire chip. Over the years, I bet I blew 7 of them with the various radios (albeit living in VA means I am in lightning country).
Flex has a partnership with a company that does repair on the firewire radios. I would create an RMA and send it for repair!
BTW, the green light only means there is voltage on the line in the firewire cable, it doesn't mean it works!1 -
it is possible both fire wire cables are bad,,,make sure they are good.
Mark, Are you running Power SDR from Flex? If so I will recommend installing Power SDR by KE9NS <https://ke9ns.com/flexpage.html> I have had similar issues in the past. My issues were traced to updates from Windows changing the firewire files. Ever since I installed Power SDR from KE9NS I have not had any issues
Sounds like maybe the wrong FW driver was applied , just go to the 1394a driver in Device Manager, delete the driver (have the radio turned off) , then reboot the computer. Give the computer plenty of time to reboot and reapply the FW driver, then power up the radio and wait ( only physical indication is the reflection of the internal green light visible from the rear ). Open the FW driver (FlexRadio icon on you desktop). Make sure your radio is showing up recognized by the computer/ FW driver. Hardest thing to make work at times and easiest to break. Hope this helps, 73, Dudley WA5QPZ1
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
- 295 Shack Infrastructure
- 207 Networking
