WSJT -X NOT WORKING
DonE
This is my second post regarding the problem. WSJT stopped working after Win update. I uninstalled the latest update but did not help. Tim W4TME spent an hour working to get my 6400 dax corrected but still WSJT does not work( no fault of Tim) I have attached two screen shots one showing the error I am getting. and one from win.10 that show WSJT-X with no volume this only comes up when WSJT is loaded .
Windows updates have a habit of assigning DAX channels as Windows default devices. This is not allowed. The second pane above clearly shows "DAX Audio RX1" as a system input device. Change this setting to a system microphone, or anything other than any DAX device.
It would be wise to open the Windows sound control panel and make sure no Flex DAX devices have a green check mark on them, which indicates Windows Default. If they do, right click on a different device and set it to be the default.
Your WSJT-X is ghosted out on that panel. What do you get on your Settings panel in WSJT?
This list will probably have things you already have set:
Audio should be DAX Audio RX1, and TX should be DAX audio TX. On the radio panel, it should be CAT
On SSDR, TX stream should be blue, and RX strewam Slice A should be blue and streaming.
As noted, in some updates the names get changed even though the drivers are probably installed correctly, they will have been misnamed by recent OS System updates:
Discrepancies, such as is shown in the above, will be plentiful and noticeable by looking at the greyed lines just under the bolder type. All I did was to rename some of the misnamed sound devices:
That said, YMMV and depending on which model you have, will indicate how many devices you will have to rename overall. In my case it is a 6300 so all I felt i needed was the two for the two slices. two for Reserved RX Audio, RX Audio, IQ RX and the one Mic and TX
One other note, which most of you of course already know is, that for each instance of WSJT-x or any other digital program, will need to be configured with a separate RX audio and Com port, and the TX audio will remain the same for those instances. Hope this is a help. '73' tnt Jim KJ7S
My audio channel names were also mangled after this last Windows update, even though I had fully uninstalled smartSDR and DAX drivers and rebooted before doing the update...
By renaming them as shown above I got it to work again ..0
- 310 Community Topics
- 564 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 153 SmartSDR for Maestro and M models
- 382 SmartSDR for Mac
- 253 SmartSDR for iOS
- 240 SmartSDR CAT
- 176 DAX
- 364 SmartSDR API
- 8.9K Radios and Accessories
- 100 FLEX-8000 Signature Series
- 883 Maestro
- 49 FlexControl
- 837 Genius Products
- 431 Power Genius XL Amplifier
- 295 Tuner Genius XL
- 111 Antenna Genius
- 261 Shack Infrastructure
- 182 Networking
- 426 Remote Operation (SmartLink)
- 132 Contesting
- 682 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 910 Third-Party Software
