Changes to Windows 10 update model announced
John WA7UAR
Member ✭✭✭
Reported by ars technica on July 24, 2019 https://arstechnica.com/information-t... Quoting first paragraph: “Microsoft outlined new directions for Windows 10's update model in a pair of blog posts. It looks like the company is shifting its twice-annual major release cycle to a twice-annual major/minor release cycle, with major upgrades in spring and minor upgrades in the fall.”
I am confused. This makes no sense to me because the reason for an update is because of a security breach or major bug.
Help me out here... Does this mean we have to wait longer before they patch a security hole and/or they will break the audio and comports only twice a year.
Secuirty patches are rolled out the second Tuesday of every month. Also known as patch Tuesday. That is not changing. As of Windows 1903 you will be able to pause patches and feature updates for up to 35 days.
https://docs.microsoft.com/en-us/windows/whats-new/whats-new-windows-10-version-1903
AFAIK the present model replaces significant portions of the OS twice a year, with planned patches on "patch Tuesday" and unplanned patches at other times.
The new model appears to make one of the twice annual events a light lift, leaving the heavy lifting to the other.
With automatic updates enabled your system will still be touched a dozen or more times each year.
With build 1903 onward you essentially can force some grouping of updates, but the expectation is an implementation delay.
Turning off updates with third party tools, higher level policy control, or adjusting your system to appear on a very limited connection looks to still be possible. The end results of deferring updates has its own risks but many hams are finding those risks acceptable. It is likely to not be possible to shut off updates in some environments and eventually the system will need updating for other program based reasons, which can become a real chore when you let it happen.
The varying implementations of Windows 10 have differing control over updates, ranging from very good control for embedded & enterprise variants to minimal for home edition & certain "lite" variants.
How the bag of update surprises plays out for any machine seems to vary based on whether it is a recent clean OS install, if it is an OS upgraded machine, resources available, what your installed program load contains, and more variables than I can recall off the cuff.
So we don't get too down on Windows, this same sort of schema is not unique to Windows 10. Most flavors of Linux have fairly well defined update programs, and when it comes to auto-updating Linux apps & packages there is an awful lot of (not well earned) trust needed at the consumer level.
The Apple iOS and macOS, as well a Google products have similar programs. I am sure we've all seen media about updates that brick devices.
Behind the scenes the great proportion of our IoT devices have under the hood update programs - whether it is your router, the modem you might rent from a provider, a security camera system, your smart thermostats or something you might not even think is connected (like the peer-to-peer connections among commercial grade kitchen appliances), I think we've all be faced with "An Upgrade is Available" message along the way. Be certain many of these devices have ways to auto-install critical updates or for support to help recover an errant unit.
Back to MS Win 10 change, without digging deeper into what is being reserved for the bigger update and what is not going to be allowed during the lighter update, it isn't possible to predict what effect each update will have on our SmartSDR systems.
It is also worth observing that the Win 10 beta testing program releases seems to always be different than the actual release rolled out publicly! From the outside looking in the divergent team efforts to build a thoroughbred (at least from that team's viewpoint) gets "cooperated" into a Frankenstein camel in the process that combines all of the team inputs into a distribution.
The massive flexibility of Win 10 is a feature than is also its weakest point when it comes to any updates.
Again stepping back from a SmartSDR Win 10 impact on DAX focus, these updates break LOTS of other programs. Whether other audio, whether CAD, whether video, or whether consumer grade games - they all take casualties by Win 10 updates.
The benefit of the updates should be in our focus - the fixes, feature expansions, security updates and more only occur via updates. Your system doesn't learn to fight off attacks or learn to offer capability extensions or even fix problems on its own.
And again that applies to any OS, especially any that are connected to the WWW.
Steve
K9ZW
Blog: http://k9zw.wordpress.com
You can pause the updates to give Microsoft the chance to patch the patch that they needed to patch the last patch.0
My MacOS install with DogPark is at 100 percent uptime. We have MacOS users in here, and I don't recall anyone complaining about updates messing up DogPark.
As well, I cannot come up with a rationale for Windows 10 to have a reason to change the names of audio drivers.
Perhaps my experience is not typical, but having supported Windows since W95, Mac since it's beginning, and Linux since 2011, update problems have been 99 percent Microsoft delivered. What is a bit scary is that the situation is getting worse, not better.
I use W10 because I have to for other work I am doing. Thank heavens for Enterprise version, I have good confidence that it will function at boot time. Other work that I am doing requires a Mac that I can control when it updates. I did have one OSX update that made it a bit jumpy years and years ago, but that was fixed in a day.
Perhaps I overemphasize uptime.
This is also a side benefit of running my SSDR on Windows 7
@Lee - largely staying on Win7 works.
Are you able to avoid other issues that tend to push us off Win7?
It is a shame that some productivity software pushes a need to upgrade Windows on us.
@Michael - what you point out about macOS is why my main machine is an iMac. It is really the one I consider permanent, as I consider the various Win10, Linux and other machines a bit more temporary or of limited use.
Steve
K9ZW
I have a conundrum with my Mac. It's a mid 2011, and fell off the update wagon. If I buy a new one so I can run Mojave, the new OS won't run W7.
So the question I will have is if anyone is running Parallels in W7 on a new Mac. I prefer bootcamp but if I have to.....
Maybe I'll retire this one for MacOS and just use it for W7.0 -
Sorry, don’t use Mojave yet, on High Sierra. I do run Windows 7 under Parallels. I have not heard that I can’t upgrade to the next OS and keep Parallels running. I _am_ nervous about the talk of dropping support for 32 bit apps (I just don’t understand why). Edit: Wait! I just read that again: “Parallels in W7 on a new Mac”. Is that what you really meant, Michael if that’s what you really meant (and I didn’t know you could do that), my response makes no sense :-)0
When I started in the computer business in 1978, I was advised that if the system is stable and functions as it should, there is no point in updates.
So I have stayed with win7 and plan to do so for the foreseeable future. Since all this PC does is run the ham shack, there isn't anything in win10 that I want or need. Also, there isn't anything on here that anybody else would want. Even if ransomed, I would restore from known good backup, and continue, or just reinstall.
I believe support ends in January for win 7.0
Dan do you mean from Microsoft ? I thought they quit supporting Win7 quite a while ago.
Dogpark runs fine on my 2015 MacBook. I will probably get one of the new minis for it. I spend to much time fixing windoze issues instead of operating. I am at the point with Windows that if DAX gets to messed up, I blast a new image on the ssd, update Windows then install SSDR. But really dogparks always works, the new minis are what I've been waiting for. So thats the direction I'm heading. I like windoze 10 a lot however, Mac always works. So with Catalina coming out and a new Mac mini, I will have uninterrupted 6600 bliss.1
And why is this a concern to Flex users? It's not a big deal. You still have monthly updates. These updates install pretty much the way that monthly updates do now. They just happen, no need to worry about them.
I'm on insider updates and get equivalent updates a least monthly, no big deal.
As an aside, I believe that the individual user is the final arbiter of their computer's security. More than Microsoft's update process - which if they have to do security updates all the time just shows they aren't doing a good job, it is incumbent for the user to use the tools at their command. While I have AV software, I consider that only partially useful. It stops something after it is already on the computer.
You need to go after the vector. This means an ad blocker at the very minimum. Ads are a great way to serve up malware. Forbes advertisers have given us the Angler Exploit Kit. This after insisting that people turn off their adblockers. There are other vectors as well.
Next on the protect yourself list is script blockers. I use Ghostery myself. helps deny a lot of tracking scripts. You can unblock a script if needed. Mostly though, if a site refuses me, I just figure they really want to place a script on my computer, so aren't trustworthy, and I move on.
And that is why I'm no more afraid to run W7 than I am to run W10. A lot of the bad guys are putting out stuff that a W10 machine can catch as well. Am I immune? Nope. But I'm pretty safe, which is the best you can hope for.
HA! No problem - and yet, I figured out pretty much what you meant.0
And to me, that's the issue. Time spent messing with my computer trying to fix it just so it works, is a real pain, and I'd rather be playing radio.
Whic brings me back to my constant whining about Flex providing a "FlexRefresh" program for especially the W10 users.
I don't think the W10 issues are going to go away, and it would be wonderful to have a program that we could run as oftern as we like that will save the profiles if we want, then go scorched earth on the Program, the drivers, Dax and Cat, and FlexVSP.
Then reinstall everything and reload the profiles, and..... a whole fresh copy of the software, started and running.
I consider starting up SSDR, having something fail, then having to go back and fix things manually, a psychological bad thing. I do it, and still love the radio, but it's too often a "Here we go again!" moment.
Much better for me to run this FlexRefresh program, have a cup of coffee while it's working, then sit down in front of the radio with a reasonable expectation that it will work is a big psychological plus. The only downside is it will reduce the number of "Windows 10 updates wrecked my radio again" complaints, so we won't get to complain about one of our favorite targets. ;^)
As an insider, can you give us Microsoft's rationale for renaming audio drivers?0
I don't need or want any of MS updates for win7. The shack computer is not connected to the net most of the time, no MS apps to update. Logging and spots are on the Ipad.
- 361 Community Topics
- 620 The Flea Market
- 8K Software
- 34 SmartSDR+
- 6.3K SmartSDR for Windows
- 416 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 929 Maestro
- 903 Genius Products
- 326 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 762 Peripherals & Station Integration
- 982 Third-Party Software
