phone operation on maestro - Radiosport Headset
Bill Carnett
Stumped again. Have Radiosport RS60CF headset. PTT adaptor/switch, all plugged in the correct ports on Maestro. When I xmit...just looks like a carrier but in reality doesn't look like I'm even transmitting. Did have it figured out a while back but can't get back there...made a mistake of downloading new software. I'm sure it is a simple fix. If I plug directly in to the 6500, works fine...so it's me and Maestro that are having an issue. Any brilliance out there? There always is. Mahalo. 73, Bill AH6FC
Make sure to select where mic is connected to the maestro. connection 1 or 2 press txmenu left side you will see mic1 and mic20
Oops upside down0
Do you have the correct mike selected?
And make sure your mic profile(s) haven't changed on you.0 -
I have also RS60CF and Maestro. For Maestro you need special cable, CS6-MAE. Too expensive, I made my own, works fine
Don’t forget the right settings for the electret/dynamic in the black box in the cable:
https://www.wimo.com/download/DIP-Switch%20setting%20of%20CS6%20adaptor%20cables.pdf
If you have electret microphone, BIAS in Maestro must set to ON and also the 20dB+ amplifier.
Thanks all for the suggestions. Will give'em a try. It worked previously so I must just have a switch in the wrong position. Aloha es 73, Bill AH6FC0
Try different profiles.0
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 179 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
