Change Nickname in 2.5.1
K5ROX
It appears yet another bug, tried restarting twice and Nickname change was lost.
Is it bug or am I missing something?
I can tell you this. Anything you change or put in under radio identification or nickname settings, you must hit enter when you done typing or it will revert back to what it was previously. That could be your problem. Hope so... Just from my experiences. Good luck 73.0
I assume you are referring "nickname" to "STATION:name". When SmartSDR is first loaded on the using computer, it uses the registered name of the computer. To change this, simply type over the name and press "ENTER." This change will remain permanent.
Jim, K6QE0 -
Enter worked.....0
Good for you., and just so you know, No It's not permanent. I know what Jim meant but,you can change it anytime but, for it to stay you must hit ENTER.... I LOVE MY FLEX........... 730
Changing "STATION:name" is problematic. The common perception is that when SmartSDR is first loaded on the using computer, it uses the registered name of the computer ant o change this, simply type over the name and press "ENTER" and change will remain permanent. Sometimes!
My observations is that you have to be login in as Admin for this to remain permanent. So does that mean that the SamrtSDR app writes a config file to the workstation. How does this work when you change workstations? How does it work when you login twice (as in a second device)?0
- 335 Community Topics
- 601 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 171 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 880 Genius Products
- 318 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 733 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
