phone operation on maestro - Radiosport Headset
Bill Carnett
Stumped again. Have Radiosport RS60CF headset. PTT adaptor/switch, all plugged in the correct ports on Maestro. When I xmit...just looks like a carrier but in reality doesn't look like I'm even transmitting. Did have it figured out a while back but can't get back there...made a mistake of downloading new software. I'm sure it is a simple fix. If I plug directly in to the 6500, works fine...so it's me and Maestro that are having an issue. Any brilliance out there? There always is. Mahalo. 73, Bill AH6FC
Make sure to select where mic is connected to the maestro. connection 1 or 2 press txmenu left side you will see mic1 and mic20
Oops upside down0
Do you have the correct mike selected?
And make sure your mic profile(s) haven't changed on you.0 -
I have also RS60CF and Maestro. For Maestro you need special cable, CS6-MAE. Too expensive, I made my own, works fine
Don’t forget the right settings for the electret/dynamic in the black box in the cable:
https://www.wimo.com/download/DIP-Switch%20setting%20of%20CS6%20adaptor%20cables.pdf
If you have electret microphone, BIAS in Maestro must set to ON and also the 20dB+ amplifier.
Thanks all for the suggestions. Will give'em a try. It worked previously so I must just have a switch in the wrong position. Aloha es 73, Bill AH6FC0
Try different profiles.0
- 650 The Flea Market
- 154 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
