phone operation on maestro - Radiosport Headset
Bill Carnett
Bill Carnett Member ✭✭
edited November 2019 in FLEX-6000 Signature Series
Stumped again.  Have Radiosport RS60CF headset.  PTT adaptor/switch, all plugged in the correct ports on Maestro.  When I xmit...just looks like a carrier but in reality doesn't look like I'm even transmitting.  Did have it figured out a while back but can't get back there...made a mistake of downloading new software.  I'm sure it is a simple fix.  If I plug directly in to the 6500, works fine...so it's me and Maestro that are having an issue.  Any brilliance out there?  There always is.  Mahalo.  73, Bill AH6FC
  • Dean Davidson
    Dean Davidson Member ✭✭
    edited July 2019
    Make sure to select where mic is connected to the maestro. connection 1 or 2 press txmenu left side you will see mic1 and mic2
  • Dean Davidson
    edited July 2019
    Make sure to select where mic is connected to the maestro. connection 1 or 2 press txmenu left side you will see mic1 and mic2 image
  • Dean Davidson
    edited July 2019
    Oops upside down
  • Rick N0VT
    Rick N0VT Member ✭✭✭
    Do you have the correct mike selected?
    And make sure your mic profile(s) haven't changed on you.
  • Laurens PD9X
    Laurens PD9X Member ✭✭
    edited July 2019
    I have also RS60CF and Maestro. For Maestro you need special cable, CS6-MAE. Too expensive, I made my own, works fine
    Don’t forget the right settings for the electret/dynamic in the black box in the cable:
    https://www.wimo.com/download/DIP-Switch%20setting%20of%20CS6%20adaptor%20cables.pdf
    If you have electret microphone, BIAS in Maestro must set to ON and also the 20dB+ amplifier.
  • Bill Carnett
    edited July 2019
    Thanks all for the suggestions.  Will give'em a try.  It worked previously so I must just have a switch in the wrong position.  Aloha es 73, Bill AH6FC
  • Robert Kearbey
    Robert Kearbey Member ✭✭
    edited August 2019
    Try different profiles.
