New Start Up --- Hardware Initialization
Ralph Fedor
My 6700 and Maestro just got back from the service department at Flex. The 6700 was drifting and the tuning know on the Maestro stopped functioning. It appears my settings were wiped clean -- OK, no problem. But, when I try to start things through the Maestro, it dead-ends on a screen saying, "Waiting for Hardware Initialization (Y, K, YTS)" What do I do?
Some people have seen this error when Maestro is NOT plugged in to AC adapter or the AC adapter does not properly seat into the Maestro...
Not sure if that is your case, but worth a try.
Paul K3SF
The connections all look good here. I double checked. Thanks
Ralph - K0IR0 -
I had the exact issue. Took it in cause I live close. It was a loose connector to the board inside the Maestro. If you feel ok with opening the case you can check easily.0
Ray --- Thank you. I think I'll run this on a ticket and see what they say. If they say, "Go ahead and open it," I'll have a look. I'm only home for a day, so it will probably have to wait a week. Ralph - K0IR0
- 328 Community Topics
- 594 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 396 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 161 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 724 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 943 Third-Party Software
