Sizeable Slice Receiver
Allow the size of the Slice Receiver to be adjustable. The panadapter can be stretched and resized but the Slice Receiver area remains the same size. Allowing it to be resized will give aid to the sight impaired.
Additionally, providing the ability to select font size and color for frequency readout and control labels will also improve operating conditions for the sight impaired.
I adjust my slice all the time.... just click and drag on the frequency bar0
You can increase the size of the slice receiver itself independent of the panadapter?
I'm talking about making it larger by dragging it diagonally
Are you talking about the flag area where the frequency is displayed? If so, I don't think you can resize it. Just the receive filter width, by clicking and dragging either side to increase or decrease the receive filter width. James WD5GWY0
No. I'm talking about the whole Slice block that contains the frequency readout, antenna selection, DAX control, volume control, Slice letter, etc. The black area containing all of these. It would be nice to be able to resize the entire slice block as well as the control labels, numbers etc.along with the pan
Hi Pat, There is also an idea to expand / contract the slice flag contents. The large size option could be a part as well. Take a look and see if this is of any interest. Like many of the gui enhancements it has been in the queue for years but maybe some day. Certainly enhancements to assist sight impaired would be good, especially if they are done in a way that the features are optional and easily selected. https://community.flexradio.com/flexradio/topics/expanded_slice_display_option_to_improve_ease_of_use If you like the idea, adding you comments would be good. Regards, Al / NN4ZZ0
I might not be understanding what you want, but try this Pat. Open up a 2nd pandapter, when you do you will now see an arrow icon beside the window and "x" that closes the panadapter, on the top right above the dBm scale.
Now if you click that arrow icon, that panadapter opens up it's own window independent of the SmartSDR window and you can resize it to full screen if you wish or move it to another monitor and make it full screen size or any size you wish.
Now re-reading your post you want the slice portion to be re-sizeable, now that would be a major re-write for SmartSDR and Maestro. Why not just connect another monitor and resize the display to be huge to your liking then move the panadapter window to that. It will give you what you want, a much larger slice to see.
As per VFO color/size that has been on my wish list and I suspect many others too. I would think all the hard coding has been done with all the routines for font size and color for spots. Now to implement same for VFO display, a very minor addition but would make many happy.
I'm talking about the entire slice control box - for lack of a better label
We can enlarge the pan but this black area stays the same size. It would be nice to be able to enlarge it and the controls within as well
I'll repeat what I suggested, Why not just connect another monitor and resize the windows display resolution to be huge to your liking then move the panadapter window to that. It will give you what you want, a much larger slice to see. I'm doing it now.
Because changing the res on the monitor tends to **** up a lot of other things. I already use 2 monitors and really don't want to add another one.
It would be a nice feature if the slice box itself could be enlarged just like the pan can be enlarged
It's called the Flag. You could also use the Windows magnifier tool to make it larger without messing with display resolution but this is a clunky option. This shouldn't be too hard for FRS to do ? Good feature request ! Minimum size flag (which is already done), full size flag and double size flag. Open a ticket and make a formal request.0
I've opened enough tickets!
I've got 3 LED monitors going for years and nothing gets **** up, a 32" in the middle of two 22". There is actually another 22" above the 22" on my right that I use when I need extra data during contesting. I also have a 6700. I have one monitor with different monitor resolution for this exact reason, eye fatigue I drag whatever work I'm doing to that monitor so I can see everything larger. Very easy solution for what you are asking.
It would be nice to resize the slice if and when FRS has no other major features to add or get caught up on. I surely would not want them to divert resources for this feature when there is lot more bigger fish to fry.
Pat you put this as an Idea, that means Flex will flag it and log the idea.
But till Flex makes the changes your asking for, and it could be some time, some of the suggestions here will get you by till such time. Otherwize, we just wait.0 -
How do you know Flex even look at any idea posted?
I never seen Flex officially posted that this or that idea is really great and they will implement in the next X version.0 -
If you really want a new feature then you must aggressively promote your idea in the Flex community and with Flex technical staff. Make some noise Pat !!0
I find good ideas get noticed and you can make all the noise you want while making a fool of yourself but a bad idea is still a bad idea. I'm not judging the re-sizable slice suggestion it does have merit but this really isn't new.
- 322 Community Topics
- 588 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 391 SmartSDR for Mac
- 257 SmartSDR for iOS
- 246 SmartSDR CAT
- 177 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 12 Aurora
- 147 FLEX-8000 Signature Series
- 904 Maestro
- 50 FlexControl
- 862 Genius Products
- 304 Tuner Genius XL
- 114 Antenna Genius
- 272 Shack Infrastructure
- 192 Networking
- 436 Remote Operation (SmartLink)
- 135 Contesting
- 711 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 935 Third-Party Software
