Smartlink Authentication issues
Jay -- N0FB
Hi Gang, I’m wanting to start using my IPad again outside my home. I initially set my SmartLink authentication to use Facebook. I have had to rebuild my IPad and the initial setup of SmartSDR for IOS is gone (same for windows and iPhone.) I cant get the SmartLink Facebook Authentication dialog to come up on my Windows Box, My Maestro, iPad or iPhone. I have checked to make sure that testing through the firewall works (I get a green light on the SmartLink screen when testing) so I’m pretty sure that the network is happy. Can someone tell me where to look to bring the FaceBook Authentication dialog back up so I can authenticate remotely? It doesn’t matter to me which platform, I’m having the same problem on all platforms. I’m pretty sure I’m making a rookie mistake. Thanks in advance!
Hi Jay, I had the same issue at first when I wanted to remote.
Your best bet is to go to google.com and create an account and sign in that way.
That is what I did and have had no issues since. Hope that helps.0 -
Although it is only my opinion, I would rather leave a third party middleman out of the picture, and authenticate with SmartLink directly, without involving Google and Facebook. I really don’t trust what Google and Facebook will do with whatever information they scrape from my interactions with them. I recognize that there may be a (minimal) increase in authentication security because of two-factor auth, but heck, who really wants to get into my radio anyway? And what are they going to do with it? If someone can guess the authentication for my radio, I have much more to worry about! I just feel a bit more in control by not sharing logins. My personal two cents worth. VE3TRQ Ted1
Ted, Very good point. The last thing I needed was another sign in and password to remember.
But you have a good point. I am just curious if anyone ever had the prompt come up and tell you to go to the radio and key it.. and then you get a confirmation tone, That happened once when setting up SmartLink. .Anyone else????0 -
I appreciate the responses Gentlemen, but I would just like to be able to get the Facebook Authentication Dialog to show again. Any ideas for this?0
I use my iPad directly with smartlink too, instant access. Ditch the Facebook login asap. Ken G0ORH1
In SmartSDr for IOS go to settings (bottom right from main screen).
Scroll down to the general section and at the bottom of that section tap on show extended settings. Select Allow Social Logins from SmartLink.
Once that is done go back to settings and Check SmartLink Status and you should be able to log in with either Facebook or Google. Dave wo2x1 -
Thank you David. This fixed my issue.
Thanks to everyone who replied. You guys & gals are awesome!0 -
Yes, I ditched Facebook authentication and I'm a happier man.1
Yes, I had to key the radio the first time I set up my Smartlink password and also (if I remember correctly) when I upgraded to V3. Only had to do it those times. Don't remember a confirmation tone though.0
Glad you got it going. There is a manual for SmartSDR for IOS available at https://manuals.roskosch.de/smartsdr-ios/ Dave wo2x0
- 333 Community Topics
- 601 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 170 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 880 Genius Products
- 318 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 730 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
