GPS Stopped Working
Mike Presnell
I have a Flex 6700 with the optional GPS.
It has always worked very well, and have used it to also discipline my transverters or other sat radio.
Today it stopped working. The first time I noticed it was after I had re-installed Windows and a new install of Smart SDR.
I have a solid Yellow Light on the radio, and blinking Yellow in SmartSDR.
The radio setup tab "GPS" is showing "GPS is active, and the status as "warming up" … but it stays that way.
Has anyone seen this before? I am wondering if I have a problem with the internal GPS unit, or the antenna.
When you did the new install of SSDR, did you do a factory reset? I is a good idea to. And check the antenna?0
Bill. No, I did not do a factory reset. Not a bad idea... wish I had thought to do so. Regarding the antenna, I am using an external marine antenna mounted on my backyard deck. All connections look good. Not sure what "tests" I can do on it however. ??0
Ok do your reset,,save your profiles in case. Sometimes the antenna connection gets damaged because it is so small, thats why I mentioned it.0
I had the same problem, I bought an identical replacement antenna from Mouser and the problem was fixed. the connector on the supplied antenna is crimped, not soldered and it can go open, try unscrewing the antenna and reconnecting it. Nothing wrong with the supplied antenna until it becomes a problem. Also, the only way I've found to "reboot" the GPS board is to remove power and do a cold boot of the radio, sometimes that fixes it. otherwise it might be waiting for a power cycle.
#FlexRadio IRC Chat73, Jay - NO5J
Jay, thanks for the comment. I am "not" using the supplied antenna. I am using an external marine "boat" GPS antenna that is mounted on my backyard deck. I use LMR400 to connect it, and the coax is about 25' long. This has worked well for me until today.
I just don't understand the Flex status messages, and there is no information in the provided Flex GPS manual. So I am trying to ascertain whether or not I have a problem with my GPS unit.
My GPS tab says "GPS is Active" and the Status is warming up.. but that never changes. If I click on "Uninstall" and then "Install" it will not show that there is a GPS attached.
I did the "reset" as BIl recommended but unfortunately, no change in status.
Open a ticket
Go into the settings menu and open the GPS tab. Delete or uninstall can,t remember which. After that reinstall GPS. I think that would do it. It will of course begins the sat acquisition and start up. Had it happen to me a while back, and that fixed it up. If it does not work, then open the ticket. Sorry missed your second paragraph, guess you already tried it.. if you have a meter check and see if the bias voltage to the antenna is present. I think it should be about 18 volts. Center pin to ground.0
You can get the warming up, indication for a long time. At least 45 minutes before I'd start worrying about it. Does it see any visible sats? That could be indicating an antenna problem or a bad antenna connection, if it doesn't. You had it working in the past.so you should know that. My point was about trying to get a better connection from the SMA connector Mine occasionally looses it, but a reconnect of the SMA connector and a cold reboot and it has always started working again, knock on wood. Sorry, but help desk ticket time, otherwise.
Years back someone else had an issue like this and they fixed it by unplugging the GPSDO and reinstalling it. Some how a bad connection had occurred. Good luck with it.
I'v had this problem a few times in the past and just the once this year on my 6700, I did spend a lot of time looking for a solution but in the end just disconnected the antenna at the SMA connector on the rig, leave it off for a few minutes reconnect and away we go again.
I had the same experience as Rob. My 6700 GPSDO has had the "yellow led" problem twice now. Each time removing and reconnecting the GPS antenna connector followed by a complete power down and reboot did the trick. Using the Flex-supplied antenna. Hope you have similar luck.
73, Tom
K1FR
IT WORKS!
This Flex Community message board is great.
Special thanks to:
Bill, VA3TWB
Jay, NO5J
Pat, N6PAT
Pat, WH6HI
John, AI4FR
Rob, G6EIH
and Tom, K1FR
You guys were all correct... that darned connector is problematic. I replaced the coax segment inside my shack (which included a new connector). Now am tracking 11 Sats!
Thanks again Flex gang!
r/Mike
WB0O
If you have concerns about where your Vehicles are going this app is for you. ToTracking System helps you to track your vehicle in real time from your mobile. So you can always monitor your vehicle movement like vehicle position, vehicle state (Start/Stop/Move), Velocity.
Troll alert!!!0
- 328 Community Topics
- 594 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 397 SmartSDR for Mac
- 260 SmartSDR for iOS
- 247 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 162 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 725 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 944 Third-Party Software
