6300 low TX output after SDR upgrade to 2.5.1
Pat Eastman
SDR upgrade resulted in low TX output power. "Tune" power gradual increase to 100% via AM into dummy load results 100W output. Doing the same using MOX as the test mode results in 25W at 100%. Thinking that factory reset may be in order? Thanks in advance.
MOX will only give you 25 watts carrier on AM this is normal.
Tune will give you 100 watts because it uses a tone (peak).
Not sure what you mean by gradual?1 -
Gradually increased TX power. Ok, so I should try FM to meter TX power output?
Why dont you want to use the "TUNE" ?1
AM mode, when transmitting only gives a carrier of 25%, or 25 Watts nominally, when transmitting. The audio sidebands use the rest of the power. To test normal roping power output, use TUNE, or CW, FM. At 100%..0
Ok, since I thought I knew what I was doing allowing me to tell the story and now that has been disproven, the output to my Ameritron 1306 is the other issue that I came up with when upgrading to 2.5.1. With the older version of SDR, it only took 40w output from the 6300 to get 1000w out of the 1306. With 2.5.1 when driven with 100% "tune" power I only get 600w from the 1306. Possibly there is something in the 2.5.1 that is affecting my amplifier/radio relationship?? Thanks again for the helpl.
Pat:
My 6600 and 6500 work well with 2.5.1.. Look at the the below suggestions, you may find some clues.
I just looked at my"TX Band settings", the HWALC boxes are checked. You might try unchecking those boxes (try one band) to see if version 2.5.1 acts like 2.4.9 on that band. With the slider set at 100 watts what does the Flex watt meter indicate (100 watts or 40 watts)? That may tell you something.
Gayle K0FLY
Ok, here is the short end to this and it comes in the form of, lesson learned.
Don't ever do an upgrade and test late at night after a long day doing yard work!! So the simple conclusion is, user error aided by assumptions.
All is well and working perfectly. Thank you very much for trying to help.
Pat
2
- 333 Community Topics
- 601 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 169 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 880 Genius Products
- 318 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 730 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
