SSDR "mirrors" Maestro with Stacks 3!
Sergey KN7K
Member ✭✭✭
First of all Big Thank you to author of Stacks3 !
Based on the post below, I was able to finally "mirror" Maestro and SSDR !
https://community.flexradio.com/flexradio/topics/smartsdr-v3?topic-reply-list[settings][filter_by]=all&topic-reply-list[settings][reply_id]=20180598#reply_20180598
This is the most desired features by many HAMs, but not sure if it was covered here and if I simply missed it.
I posted a video on the performance, however I can only use it in a "mirror" or "sync" mode on Slice A. I cannot make a 2nd Slice (B) to do the same as A. Can someone confirm if you can make 2 slices on SSDR to follow Maestro? Here is the link to the video:
https://drive.google.com/open?id=1xfAWhVzVVXDY_tRFTj032J_1RlxFymYq
Here the feature desribed on Stacks3 website:
"Sync Client Slices feature will keep clients' slices in sync with each other. The purpose is to allow the use of Maestro as a control surface for SmartSDR when co-located. You must not bind to a client for this feature to work".
I am not sure what "co-located" means, same band?
I think Flex should have this feature a long time ago as this make Maestro usable with Big screens!
Sergey, KN7K
Sergey, KN7K
2
I also want to thank the Stacks3 author for the ability to mirror a slice between the Maestro and SSDR.
I tried to set my 6700 to SO2R mode after successfully mirroring a single slice using Stacks3, but everything went haywire. The PTT was clicking madly and the only way to regain control was to change to a single slice preset.
Maybe it's something that can be fixed, but I thought I should at least raise the issue so everyone's aware of it. In the meantime, I can either stay with Maestro only or use the 6700 as Radio 1 (with mirroring) and my Yaesu FTdx5000 as Radio 2. The latter definitely has all the knobs and buttons a ham can possibly want. ;-)0 -
co-located means SSDR PC and Maestro located in front of you at same location.
I have a 6700 with 3.0.27
on maestro 2 panadapters with one slice each A and B
on SmartSDR 2 panadapters with one slice each A and B
Sync with FRSTACK and slice A on maestro controls slice A on SSDR
same with slice B on second panadapters
smartsdr controls maestro also, they are sync'ed
You can have A and B slices on one panadapter also0 -
Larry,
Thanks for the info.
I could not work it before, but may be sequence was wrong.
Eric, please try that sequence, seems like it works:
1. Start SSDR abd Maestro
2. Open 2nd panadapter on SSDR and Maestro
3. Setup slice A to 6m, slice B to 12m on SSDR (can use different bands, this is just what I used).
4.Maestro Slice A to 6m, Slice B to 12m
5. Stacks3 set to "Sync Clients"
So far it is WORKS !!!, but need more time for testing.
Sergey, KN7K
The Client Sync'ing features works fine here. Once again, my hat is off to Mark! Thank you!
Sergey,
Many thanks. It does work this way until I open N1MM+ for logging and control and try to switch focus. Then some funky things happen - both slices seem to go to the same band and PTT clicks rapidly with flashing screen. The only way to stop this is to close N1MM+, but then the Maestro and SmartSDR seem to have lost sync. I suspect I'm pushing things one step too far.
If I open N1MM+ with just Maestro or just SSDR, all is well. I can toggle from one slice to the other and everything seems to be happy.
73 de NC6K0 -
Well, I still testing 2 Slices and believe there is an issue here.
While I successfully listened 2 bands independably few hours ago, I just got to the radio this evening and on slice B (12m) changed band to 80m.
While I changed band on Maestro slice B, everyting getting in confusion, here what I see:
1. There are some clicks inside of the radio during the switch, lasting 2-4 sec.
2. Antenna Genius confused as it shows Slice A and B on the same antenna with red color (not permitted by my settings).
3. Maestro shows A -6m Wide, B-80m wide
4. SSDR A shows 80M (80M band but A in the right side of panadapter/in the corner pointing to 6m band
5. SSDR - B still shows 12m.
So, while 1 slice performance is good so far, there is something wrong with 2 slices (2bands setup).
Again, maybe I am doing something wrong and would like to hear from others who tried it.
Sergey, KN7K0 -
Yes, see my post below.
Something not reliable with 2 slices and I cannot make sence of it yet.
I did not try with N1MM yet, just trying to learn and understand the logic.
Sergey, KN7K0 -
I think our responses overlapped. Yes - 2 slices is problematic, especially with any other rig control software involved.Clearly, this will work eventually, but for now, it's definitely not suitable for prime time.0
A key reason I bought an M model, rather than a 6400/6600 and a maestro, was to use the provided HDMI connector for large screen mirroring (no PC necessary).0
Neil, I got 6600 and Maestro as I see this combination has more benefits (for me) compared to the M. For each it’s own, right? Sergey, KN7K0
Absolutely, Sergey. If I had a strong need to operate remotely from the radio, I would have done the same thing. However, I think some don't take the HDMI connector into consideration when making the choice.0
I have a 6700 that I bought several years ago, so no option other than to use SSDR with big monitor.
On the bright side, I have set up N1MM+ with bandscope and am using Maestro for control. That gives me 95% of what I need (readable band display with spots and the ability to use the real knobs and buttons on the Maestro).0 -
Eric,
Could you share your n1mm settings either here or in email? My email is at qrz dot com
One more things to experiment - I was changing bands from SSDR last night and that could confuse my antenna setup. Need to try to change bands from Stacks where I have saved settings per band and mode. Also, not sure what to choose at Stacks3 in sync mode: on the left side you choose Active - Maestro or SSDR, I think it does not matter in Sync mode, but need to test it.
I will not have much time today, going out till late evening.
Sergey, KN7K0 -
Tried again few different scenarios, here is the one that I do not understand:
https://drive.google.com/open?id=1leWewgcVvF8YxfVIsr8zDc_rsjQe14i_
See what happening on the 2nd panadapter.
Larry, W8LLL could you please share more details on your settings.
Sergey, KN7K
No special settings, I duplicated what you showed in the video and see exactly what your seeing. A small move of the B VFO knob on the maestro brings the 12 meter slice back into view.0
- 334 Community Topics
- 601 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 170 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 880 Genius Products
- 318 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 730 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
