smartsdr version 1 updates
Trevor-EI2GLB
Has development of Version 1 of SmartSDR been stopped, is v1.11.12 from 2017 the last v1 update there will be,
Trevor
EI2GLB
Trevor
EI2GLB
Yes Development of new features for V1 and V2 has terminated Except for bug fixes0
I'm disappointed by this too Trevor. I (~50 years+ with computers, EE) have a growing distaste for having to get online & linked to something to get anything done - and have zero faith in this for potential emergencies.1
An "M" series radio doesn't need a computer or being "online" to operate, emergency or otherwise.
For the other radios, while you DO need a computer or a Maestro, you do not need to "get online" to operate. A single network cable between the radio and the computer is all the "online" you need.
And that is true for all versions of the software.
3 -
I can certainly understand the "No new features" in version 1 software. However, it would be really nice if the 'bug fixes' included NR and WNR that actually worked. My NR distorts audio so much it is not worth using even at its lowest level and WNR does nothing at any setting. I love my 6500 and it works great on all modes but this is one thing I think should be fixed in my current release. Jim KD1I1
Well, I am now running a Flex 6400 1E for Field Day. Flex and router on a 100AH AGM battery and iPhone, on battery.0
I am possibly mistaken - but remember I did not say "connected" I said only online:
Item: "An "M" series radio doesn't need a computer or being "online" to operate, emergency or otherwise."
If the M-series completely eliminates the need for Windows, and the need to link to Flex for s/w and licensing this would be ... interesting. I was concerned with standard F6xxx in maritime mobile and other marginal www-access situations.
Quick summary:
- Internet is need for version upgrades and for SmartLink
- M-models are self contained (theirs is am embedded version of Windows BTW) and also only need the internet for version upgrades and for SmartLink.
- You CAN take ANY Flex-6000 to the field (or ANYWHERE off the Internet) provided you provision a LAN or direct connection from the operating device (PC, Tablet or iProduct) that is not internet dependent. Again the only time you need the internet is for version upgrades and for SmartLink.
SmartSDR (Windows/iOS/Maestro/M-Model) in LAN operation NEVER requires the internet. But SmartLINK always does.
Again SmartSDR Version 1.x while not depreciated is in the maintenance-only phase of its life cycle. I'm thinking SmartSDR Version 2.x has also enter that phase. The Pre-Release SmartSDR Version 0.x I think is depreciated.
You do not HAVE to use the features of a higher level of SmartSDR to benefit from the code improvements. So often people post they are not going to move to the latest version because they have no need for the major feature the new version offers. I'm thinking they largely miss the opportunity to gain all the improvements they would benefit from even if they never use the "big feature" that was added.
Interesting stuff - the move to version 2.4.9 to 2.5.1 is a biggie, as version 2.5.1 truly is "Version Two and a Half" transitioning to a subset of the Version 3 code. While some folk seem to find this an "issue for their knee-**** complaints" I'm seeing this as providing a long term way to support Version 2 rather than depreciating that level.
It doesn't seem very likely Version 1 or Version 2 will gain any significant new features, and unless something happens that makes Version 1 not to run (unlikely at the radio end, but at the GUI Windows end something might change making that happen) one doubts that Version 1 will see any changes.
I could have some of this wrong, and to stave off the usual comments I don't work for FRS and I cannot speak for them. I'm commenting by looking at the same information you all are.
Steve
K9ZW
Blog: http://k9zw.wordpress.com
I can't understand how this has turned into a tin hat I'm scared of the internet thread, I just wanted to know was there any more updates to v1.11.12 planned and the answer looks like no there is not, I personally think the newer software is too expensive but I suspose Flex aim there products at the very high end, Thanks Trevor EI2GLB0
A good, complete reply. (I do confess to ~luddite sentiments - after 50+ years in hamming/computers (systems, development, admin) I am a bit sad to see my old hobby drowning in the 'standard arcana' - and essentially un-field-repairable.)0
Concur. I am personally unhappy that Microsoft/Windows is involved in any context.0
Alex, You could run Dogpark on an iMac or SmartSDR IOS, then Windows is not involved. Just a alternative thought For field repair, radios like autos are more reliable today than many older radios, and don’t require the repairs. I do remember the same comment when transistors were first coming to market, but were so much more dependable. Dudley, WA5QPZ0
Greetings Dudley! It is my understanding that Windows is still required at some point to load the F-boxes -- true/false? I, too, passed from tubes to transistors ... but having been a military brat in some unusual places, and an embassy info-security officer, I remain only impressed with the growing vulnerability of many systems in their elaboration and dependency on the continuous availability of the www. I have harped on Flex to go to BITE & VME card cage architecture for this reason.0
- 332 Community Topics
- 600 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 262 SmartSDR for iOS
- 247 SmartSDR CAT
- 182 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 169 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 855 FLEX Series (Legacy) Radios
- 877 Genius Products
- 315 Tuner Genius XL
- 116 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 729 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
