SmartSDR Ver 2.5.1 DIVersify fails to center audio left and right when switched off
ai6re
After using DIV (diversity mode) in SmartSDR Ver 2.5.1 the audio stays shifted to the Left in Slice A and to the Right in slice D when DIV is switched off. You must manually move the audio balance back to the center after using DIV.
Where is this option DIV located on Smart SDR 2.51????? I have not seen this option?0
It is on the bottom of the Slice Audio dropdown
Here is a picture of DIV when turned on. Ant 1 is a SteppIR and ant 2 is R9 Vertical.
Wow, I don't have that option available No DIV. Can anyone tell me why?
I am using a Flex 6300 with the 2.51 update. Please any info on this is appreciated.
Please See Photo attached0 -
The 6300 and 6500 do not have diversity reception as they only have one SCU - signal capture unit. You must have a 6700 to perform diversity reception.0
The 6600 will do diversity also. I've noticed your issue with earlier version 2.4.9 as well.0
Good point, Cal. I am not familiar with the 6400 or the 6600. Thanks for your input. Jim0
- 332 Community Topics
- 600 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 262 SmartSDR for iOS
- 247 SmartSDR CAT
- 182 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 169 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 855 FLEX Series (Legacy) Radios
- 877 Genius Products
- 315 Tuner Genius XL
- 116 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 729 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
