Heil Headset with Flex 6500
WP3C
Hi everyone Someone that can help, I connect my Headset and as soon as Inconncet it start to change the frequency. I put a hand mic ( Yaesu) and works well. If someone have info about how gangs the connection of the headset to make it work with my 6500 I will really appreciate it. Thanks
SOME Heil connectors will fit the 8-pin foster connector 1 pin off, I have seen this happen because of this. the connections on the Yellow/Yaesu adapters is usually fine if they haven't been changed with the exception watch the chassis ground being tied to the mic element - minus lead and causes RF on mic audio sometime's.
Yes. Some of them would even go in upside dow in the early days. Look carefully. Also be sure that the Heil adapter is for Yaesu or Flex. The Kenwood and Icom ones are wired differently.0
Wire it for a yaesu ftdx 3000 Google diagrams0
Before the FLEX I used it with a Yaesu FTDX3000
I already solved the problem. Thank you all
Well share the issue so others will know0
I had the black wire in # 8 and the white wire in # 1, I switch it and it worked.
- 371 Community Topics
- 93 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 246 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 451 Remote Operation (SmartLink)
- 996 Third-Party Software
