V2.4.9 update 2.5.1 issue with audio in JTDX - WSJT-X
Pat ON3CQ
V2.4.9 update to 2.5.1 issue with audio in JTDX and WSJT-X. When I start SmartSdr and JTDX, it sets the DAX RX Stream Slice A to input 70 in the software JTDX or WSJT. I have the Slice A on 19, these settings were good in V2.4.9. If I now set Slice A to 18 and immediately back to 19, the input is ok again in JTDX. This problem was not there in V2.4.9 someone info where the problem is located.
73 Pat
73 Pat
I'm having the same problem. It appears that the DAX software does not read the value of the control sliders at startup. My receive DAX levels are always high. If I move the slider control to a higher level, the indicated audio level decreases then starts to increase as I increase the control. If I decrease the control, the audio level decreases and then continues to decrease or increase as I change the control. I have to wiggle the slider each time I start the DAX.
Gayle K0FLY1 -
Same here. Below is an email I sent to another Flex owner describing this issue.
"Please take note that if you change bands using profiles or the BAND selection that the RX DAX is amplified even though the setting there is the same. Say you are on 20m FT8 and on wsjt your received signal strength is 30dB, using profiles to change bands to say 40m or even 20m, the received signal strength at wsjt is now at 80dB. Turning off the DAX RX and then back on or changing it will correct the issue. For example say you have DAX RX at 22 and you change to 23 or 21, the RX signal will go back to normal."
If I use other software besides SSDR such as wsjt to change bands DAX works fine.
Today I also tried with a new profile, but this does not solve the problem. Created a profile with the DAX RX disabled but this does not solve the problem either. If I then switch on the DAX RX, the value is again too high.
Pat ON3CQ0 -
Good morning, I regret to disagree, but what you are saying in v2.4.9 does not happen.
the level is always the same and stable, you do not have to touch any control to work correctly.
What is certain is that the new version of Wsjt-x which includes ft4, makes your computer raise the audio level to the maximum and therefore instead of staying in the program in 60 and in green in case of wsjt -x does not do it.
You have to enter the sound configuration and lower the audio level.
but this is a failure of the wsjt-x
I am working with the smartsdr 2.4.9 and the version wsjt-x 2.0.1 and with jtdx 2.0.1-rc135 and I do not have that kind of problems.
However, if I start wsjt-x 2.1.0 then what has been said above happens.
EA4AYW What you are saying is a known issue with the RC version of wsjt-x under the 64 bit version of that program. We are not talking about that at all. In fact I am still running version 2.0.1 of wsjt-x and not any of the newer versions with FT4 capabilities. But if we can lets forget about WSJT-X. The same issue described above from the other folks happens on my logging program MixW2 as well. I first noticed it in this weekends RTTY contest at which time I went back to version 2.4.9 and could again change bands on the fly without worrying about bringing up DAX to correct the audio issue.
We are aware of this issue (DAX RX Gain sometimes not syncing) and have it in our system as #7578. Thanks for reporting this and helping us to understand what you are seeing.1
- 384 Community Topics
- 641 The Flea Market
- 148 SmartSDR+
- 436 SmartSDR for Mac
- 262 SmartSDR CAT
- 282 FLEX-8000 Signature Series
- 960 Maestro
- 935 Genius Products
- 343 Tuner Genius XL
- 798 Peripherals & Station Integration
- 142 Amateur Radio Interests
