FRStack Version 3.0.25.5 Released
Mark_W3II
Member ✭✭✭
Radio versions starting with SSDR 2.5.1 and 3.0.19 share the same API interface syntax.
This release has been tested with SSDR 2.5.1 and 3.0.27.
- Add Demodulation MODE hotkeys
Note: If you are using SSDR V2.5.1 or later you must use FRStack V3.0.25.5 or later.
Full release history can be found at http://www.mkcmsoftware.com/Flex/Index
web link only has FR v3.0.24???
Bill--K5ZQ0 -
It is actually 3.0.25.5. I will update the website text. Thanks for catching this.
The site text is updated now.0 -
Looks good, Mark. I will download. Nice talking to you last evening. -- 73 de Carl N8VZ
I am running SSDR 3.0.27 and frstack 3.0.25.5
When changing global profiles FRSTACK totally locks requiring task manager to end the task. I am seeing this behavoir on two differant win 10 home pc's, anyone else seeing this?0 -
Larry, I tried it with v2.5.1 and stack 3.0.25.5 and it works FB. Also using win 10.
73 Bill K5ZQ0 -
I found the issue. I will be releasing 3.0.26.6 an update shortly.2
That fixed it, Thank you!0
v2.5.1 Win10
If I start the previous version of FRStack, I get a message to downgrade the radio to v2.4.9 or upgrade to FRStack3
If I start FRStack 3.0.26.6, the message tells me currently no radios available.
My 6500 is connected directly to the computer.
This is almost always a firewall rule. Look at your windows firewall settings and make sure the new installation has a firewall rule in place for it. You could try uninstalling FRStack3 and then resinstalling it.0
Thanks, I'll take a look at that when I get home this afternoon.
FRstack is my favorite add-in, and justg keeps getting better
firewall rule was the problem, thanks
I cant use frstack because I use wifi here. It would mean having wires trailing over the shack floor into the other room where the router lives!
Hi Roger, I use FRStack on my local PC, over WiFi to my router. FRStack uses SmartLink to connect to my remote Flex that is miles away. FRStack works great over local networks and without any absolute need for a physically wired Ethernet connection.0
Hi John. Just tried and got mine to work using smartlink, but not using smartlink on the Flex, just FRStack. Many thanks for that.
- 378 Community Topics
- 119 SmartSDR+
- 193 DAX
- 38 Aurora
- 260 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
