Upgrade to 2.5.1
Gary
Gary Member ✭✭
I upgraded my 6600M to 2.5.1. after doing so, I had to set up all my profiles. When I turn the radio off and on, the profiles are gone! I down graded to 2.4.9 and my profiles are gone as well. Have not recreated the profiles and saved them again the the downgrade.
  • Jamie WW3S
    Jamie WW3S Member ✭✭
    edited June 2019
    Did you follow the suggestion in the original email to back up your profiles prior to updating?
  • Gary
    Gary Member ✭✭
    edited June 2019
    Yes, but even if I had not, Creating a new profile should keep that profile on power down and power up.
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited June 2019
    If you saved your profiles to a file, even on a thumb drive? were are they?
    Lesson learned, save your profiles. Keep a file safe to use at any time you may need it.
    And save your 2.5 profiles as well. The profiles created in 2.4.9 are not compatible with v2.5
  • VE3DZP
    VE3DZP Member ✭✭
    edited June 2019
    Bill I also did the up grade, saved my files on a thumb drive but they where not needed? That to me means they are compatible no? I will back them up on a new thumb drive just to be safe. Gary
  • Bill -VA3WTB
    edited June 2019
    Yes thanks for pointing that out. I should have said that v2.5.1 profiles are not compatible with earler versions.
