Upgrade to 2.5.1
Gary
I upgraded my 6600M to 2.5.1. after doing so, I had to set up all my profiles. When I turn the radio off and on, the profiles are gone! I down graded to 2.4.9 and my profiles are gone as well. Have not recreated the profiles and saved them again the the downgrade.
Did you follow the suggestion in the original email to back up your profiles prior to updating?0
Yes, but even if I had not, Creating a new profile should keep that profile on power down and power up.0
If you saved your profiles to a file, even on a thumb drive? were are they?
Lesson learned, save your profiles. Keep a file safe to use at any time you may need it.
And save your 2.5 profiles as well. The profiles created in 2.4.9 are not compatible with v2.50 -
Bill I also did the up grade, saved my files on a thumb drive but they where not needed? That to me means they are compatible no? I will back them up on a new thumb drive just to be safe. Gary0
Yes thanks for pointing that out. I should have said that v2.5.1 profiles are not compatible with earler versions.0
- 379 Community Topics
- 636 The Flea Market
- 141 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 462 Remote Operation (SmartLink)
- 793 Peripherals & Station Integration
