2.5.1 Install
W1MSG
Installed 2.5.1 and when I start the program the radio goes to a double red flash on the power button and reboots.
did you do a factory reset???
2.5.1 notes identified factory reset needed
Yes I did, will try it again a little later..0
If you continue to have trouble, please open a helpdesk ticket at http://helpdesk.flexradio.com so that we can provide direct assistance.0
Eric, I did a reset again and it worked just fine.1
Just about to download v2.5.1. So I should read the release notes, and I will but after I download v2.5.1 I need to do a factory reset?0
Yes you should Steven, it should go really slick,,mine did.0
I think what some have done is click on the wrong icon,,the old one...
I delete my old ones so I don't make that mystake.0 -
I did not do a reset, and it installed OK. The Best Practices sheet make no mention of this & tells to do a Cold Boot. A formal FLEX update/upgrade procedure is needed and should be included with the new s/w.
I did make the mistake of clicking on the pinned to toolbar SSDR icon I had for 2.4.9 which prompted me to "downgrade". When I figured out the new s/w did not update the icon like some developers do, I unpinned 2.4.9 & pinned 2.5.1 & all was good.- Bob W8RMV
Did a cold boot after installing per install notes. Worked fine. Zero issues.
- 328 Community Topics
- 593 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 396 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 158 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 872 Genius Products
- 311 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 438 Remote Operation (SmartLink)
- 135 Contesting
- 721 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 942 Third-Party Software
