DXLab Commander and today's new SmartSDR releases
Commander 14.0.8, which was publicly released on May 28, was tested with SmartSDR 2.5.0 and SmartSDR 3.0.25. I used the latter to make many QSOs; it performed flawlessly with my 6500
Today, Flex publicly released SmartSDR 2.5.1 and SmartSDR 3.0.27, neither of which I had the opportunity to test beforehand. I successfully made a few FT8 QSOs with each release. In both cases, I initially encountered a failure of my 6500 to activate my amplifier, which I worked around by setting the Transmit Profile selector to SO2R_TX1. I also observed several instances of "spontaneous disconnection" between Commander and SmartSDR, followed by an automatic reconnection; I'll be adding some diagnostics to Commander to track down the root cause of this behavior, and will report the results here.
Note that Commander 14.0.8 also supports SmartSDR 2.4.9.
Dave,
I'm still at 2.3.9. will it work with that as well?
I have not tested Commander 14.0.8 with SmartSDR 2.3.9, but I don't know of any reason why it wouldn't work correctly. If you decide to try it and run into trouble, please post a message on the DXLab Discussion Group, which I monitor more frequently than this forum.0
My 6700 is in the shop but I'll give it a try as soon as I get it back
Always a pleasure to use your software.
Hello Dave...I upgraded today and worked some FT8...I was also experiencing "spontaneous disconnection" between Commander and SmartSDR, followed by an automatic reconnection;...I know you will be working on this issue...Just FYI...Thanks for all you do.
Ronald0 -
DAVE -
Thanks for your comments and the update! Your hard work on DXLab hasn't gone unnoticed and is very much appreciated!
As noted in the original post above, while testing SmartSDR 2.5.1 and after upgrading to SmartSDR 3.0.27, I've experienced several instances of "spontaneous disconnection" between Commander and SmartSDR, followed by an automatic reconnection. I have been working to track down the cause of this behavior, but SmartSDR provides no indication of why it has dropped the connection to Commander.
SmartSDR provides a "keepalive" option that, when enabled, will automatically disconnect if it hasn't receive a "ping" message from Commander within the past 15 seconds. Depending on network speed and congestion, it's possible that conveying a large number of callsigns to SmartSDR - after a band change, for example - could result in 15 seconds elapsing without a "ping" being sent. I have a new version of Commander that prevents this by automatically sending "ping" messages while conveying callsigns to SmartSDR. So far, I haven't seen a spontaneous disconnect while testing this new version.
If you have Commander controlling a Flex Signature transceiver, have been experiencing spontaneous disconnects, and would like to try this new version of Commander, please send an email message to me via
aa6yq (at) ambersoft.com
- 332 Community Topics
- 600 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 182 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 169 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 855 FLEX Series (Legacy) Radios
- 877 Genius Products
- 315 Tuner Genius XL
- 116 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 729 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
