2.5.1 Install
W1MSG
W1MSG Member ✭✭
edited March 2020 in FLEX-6000 Signature Series
Installed 2.5.1 and when I start the program the radio goes to a double red flash on the power button and reboots.
  • K3SF
    K3SF Member ✭✭✭
    edited March 2020
    did you do a factory reset???
    2.5.1 notes identified factory reset needed
  • W1MSG
    W1MSG Member ✭✭
    edited June 2019
    Yes I did, will try it again a little later..
  • Eric-KE5DTO
    edited June 2019
    If you continue to have trouble, please open a helpdesk ticket at http://helpdesk.flexradio.com so that we can provide direct assistance.
  • W1MSG
    W1MSG Member ✭✭
    edited June 2019
    Eric,  I did a reset again and it worked just fine.
  • Steven WA8Y
    Steven WA8Y Member ✭✭
    edited June 2019
    Just about to download v2.5.1. So I should read the release notes, and I will but after I download v2.5.1 I need to do a factory reset?
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited June 2019
    Yes you should Steven, it should go really slick,,mine did.
  • Bill -VA3WTB
    edited June 2019
    I think what some have done is click on the wrong icon,,the old one...
    I delete my old ones so I don't make that mystake.
  • Homer1952
    Homer1952 Member
    edited June 2019
    I did not do a reset, and it installed OK.  The Best Practices sheet make no mention of this & tells to do a Cold Boot.  A formal FLEX update/upgrade procedure is needed and should be included with the new s/w.
    I did make the mistake of clicking on the pinned to toolbar SSDR icon I had for 2.4.9 which prompted me to "downgrade".  When I figured out the new s/w did not update the icon like some developers do, I unpinned 2.4.9 & pinned 2.5.1 & all was good.- Bob W8RMV
  • Lionel
    Lionel Member ✭✭✭
    edited March 2020
    Did a cold boot after installing per install notes.  Worked fine. Zero issues.
