updated to 3.0 for my 6400 m cant get ft8 to work plus all kind of bugs
David Kowell
Hi David, Please be a little more specific. Did you upgrade from version 2?
And, if so, did it work on version 2? Plus what are some of the bugs you are
referring to ? And WSJT, what does it do or not do. Receive, transmit, or both?
73, Jim N9VC
When I went to V3.0.19 with SDR iOS
After a few transmissions, Transmit PTT
Locked up !!! V3.0.19 not stable, crash after being on A few hours Also, Tried MultiFlex between SmartSDR On PC and IPhone SDR iOS No Tx Audio on iPhone Anyway, went back to V2.49 !!!!! Lots of Bugs !!!! What can I say Flex !!!! Bug City !0 -
Sorry, you're having troubles, Mike. You might have to check with
Marcus about SDR iOS. I am running version 3 here with no problem
as I am sure others are. Some of the things to check would be a
setting that changed, easier said than done. I take snapshots of my
screens so I have something to compare should I encounter some
problem. Because the minute I say everything is fine, watch out. I
can post screen shots for comparisons if necessary. Dax channel numbers
might be different, but the concept is the same. I run WIN 8.1 here
just because WIN 10 has been the source of some of the problems.
73, Jim N9VC
Another ham here running version 3 on my 6400 with none of these issues. It may be worth noting that my 6400 came with V3 on it, though that shouldn't matter. Anyway, I run SSDR, SliceMaster, WSJT-X and HRD all at once on Windows 10 via Parallels on my Mac with no issues. Thus, I'd be hesitant to blame V3 in particular, though you may need to update SSDR as well as all your other apps to get things working well on V3.0
Did you reset the radio after the upgrade? I saw the same issues with my flex-6500 until after a rest..0
I did not do a reset after v 3.0 install I am running windows 7 here cw skimmer slice master wsjt inop along band change/antenna port problems went back to 2.4.9 all is well
David, you should do a factory reset. Otherwise strange things can happen.0
Issueless FT8 following upgrade to 3.0 on my 6600M here.0
You should ALWAYS do a factory reset after any firmware upgrade to the Radio...1
You'll want to check DAX and CAT to ensure that they are still set the way that WSJT-X is set up. Also check your DAX rx and tx settings in WSJT-X.0
checked all settings for wsjt and cw skinner checked dax settings
Do factory reset of the radio..0
did factory reset I think still have problems is there anyone here that will let me call him / her to talk tnx0 -
Dave, I need to run up to a tower site for a couple of hours. I'd be happy to connect in via TeamViewer and help you. You can watch what I do in the process.
If you are interested email me at my call at arrl dot net with your number and I'll give you a call.
thank you very much tnx k2cka /kj4mcz0 -
Just a follow up, I was able to get Dave's issues resolved. WSJT-X was reconfigured to use the TCP port connection in CAT and reset RX & TX levels.
Updated his radio to 3.0.27.
Also updated and configured his CW Skimmer & OmniRig to work with the new 3.0.27 release.
He is a Happy Camper!
now if flex radio had people like david wo2x on the pay roll they would have tech support
- 379 Community Topics
- 636 The Flea Market
- 141 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 956 Maestro
- 57 FlexControl
- 931 Genius Products
- 301 Shack Infrastructure
- 793 Peripherals & Station Integration
