flex 6500 timeout
Ugggh.  I fired up my 6500 for the VHF contest just now from my rare grid.  It seemed fine and the Maestro saw it but needed to update the 6500.  Now the 6500 times out and will not boot.  Only 2nd time I have used it as it is my back up to my 6700.  Any help out there?  Quiet at EN48.
Welcome!
  • Member ✭✭
    edited June 2019
    Corrupted sd card probably
  • Member
    edited June 2019
    any fix in the field for it?
  • Member ✭✭
    edited June 2019
    I actually searching and I'm seeing call in they have some specific reset to try and if that fails send it in . Also see where the sd card slot in on a board and 1 guy pulled and reinstalled sd card and it fixed it . I suppose that's whatever u wanna try
  • Member ✭✭✭
    edited June 2019
    Hold the power and ok buttons in at the same time to do a factory reset.
