ATT iPhone X Personal Hotspot problem
Can’t get Maestro to login to above hotspot I find the iPhone personal hotspot wifi on the network screen. I select it, and I get the password prompt. After entering the password screen, the display reverts to the password entry prompt. Even after multiple (correct) password attempts, the Maestro never successfully logs on. Any suggestions? I’m at a motel where the bw fluctuates wildly, and even the low bw connection is unreliable. Thanks John
I would try rebooting your phone!! I have found this to fix many issues I occasionally have.. Also be sure to swipe your screen to see all the apps that are open, and close them all out! Good Luck..0
sounds like the Hotel may have a captive portal (a we page that basically authorizes your mac). Maestro does not support this authentication type at this time. You can search the community I think a few have found ways around this, but they are fairly creative and may not be that easy.
reading again and if your phone is able to get online.. that is probably not the issue. not sure.
Are you trying to use 4G on the iphone or WIFi to connect to the internet? If ur trying to use the iPhone X as a hotspot via Hotel Wi-Fi it can’t share internet connection on Wi-Fi.0
Does your iPhone have an apostrophe in its name? That is the apple default and it’s also used for the SS ID on the personal hotspot. The maestro does not like apostrophes in the SS ID name and will behave the way you described. If there’s an apostrophe, take it out and you should be able to login just fine.3
I should have responded earlier. Chuck's response is exactly correct. After removing the apostrophe, I was able to log in normally. I was surprised that the iPhone hotspot's bandwidth is sufficient for an excellent, reliable connection. I have been using 4G--not using WiFi.1
I have had to use iPhone personal hotspot because of captive portal issues in Reno0
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 176 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 881 Genius Products
- 318 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 735 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
