SteppIR help with Flex 6400M
Andy W3LI
Has anyone sucessfully married the Flex 6400M to the SteppIR SDA 100 Controller? Yes I have the plug in board in the back of the controller. Also, have purchased the USB-64 cable from rtsystems with the FTDI chip installed. Lastly I purchased the S12 cable from SteppIR.
Neither the Flex manual or the SteppIR manual (old) or new Mustang manual give any info as to what one should do with all of this cabling.
I know that the Controller has to be set up for Autotrack.
If any of you folks have gone thru this setup I would appreciate some guidance.
Andy...W3LI
Andy...W3LI
There is a very nice write-up in the USB Cables document which you can find in the downloads section of SmartSDR for Windows - How to Guides. I followed those directions and had no problem getting my original SteppIR controller to track my 6700. Works like a champ.
Keith - AC9S1 -
i have Steppir work with 6600 just fine.
Setup your protocol in SDA100 as Kenwood in Mode Setup, Baud 9600.
Sergey, KN7K1 -
Tnx Sergey. Need to find out where all of these cables go first.
Andy0 -
Also connect the cable to the top serial port (Data in I think).0
The document that Keith refers to above has all the details and is available here:
https://www.flexradio.com/downloads/usb-cable-interface-guide-pdf/?wpdmdl=3089&refresh=5cf991f50...
Tnx Craig, I did find the item that Keith sent. I have copied same and will save in the SteppIR manual.
Tnx for ur help.
Andy...W3LI0
- 379 Community Topics
- 634 The Flea Market
- 135 SmartSDR+
- 199 DAX
- 43 Aurora
- 956 Maestro
- 301 Shack Infrastructure
