I noticed that my 6600M will not go to the uppder band edge on 17 meters. It cuts off transmit at 18
Gary
17 meters band edge
Might you have been in SSB or DIGU mode. My 6600 cuts out at exactly 18.168.0
That's normal. It's to keep you from transmitting out of band.0
Thank you, guys. I heard a SSB QSO on .164 this morning with really good signals and wanted to join. They were on USB.0
You need to look at how wide your transmit bandwidth was set to. To operate 18.164 USB your transmit bandwidth needs to be under 4 Khz wide or you would go outside the band limit of 18.168.1
Thanks., I’ll check. It should be at 2.7 like my other bands. But it could be on my AM profile. Very good input and thank you. 73’s0
The TX Filter setting was the problem. It was using the settings from the AM profile and once set to 2.7K, all is well. Thanks to all for your help and thanks to all that have served our Country.0
- 361 Community Topics
- 622 The Flea Market
- 8.1K Software
- 48 SmartSDR+
- 6.3K SmartSDR for Windows
- 180 SmartSDR for Maestro and M models
- 417 SmartSDR for Mac
- 269 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 226 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 289 Shack Infrastructure
- 203 Networking
- 141 Contesting
- 985 Third-Party Software
