I noticed that my 6600M will not go to the uppder band edge on 17 meters. It cuts off transmit at 18
Gary
17 meters band edge
Might you have been in SSB or DIGU mode. My 6600 cuts out at exactly 18.168.0
That's normal. It's to keep you from transmitting out of band.0
Thank you, guys. I heard a SSB QSO on .164 this morning with really good signals and wanted to join. They were on USB.0
You need to look at how wide your transmit bandwidth was set to. To operate 18.164 USB your transmit bandwidth needs to be under 4 Khz wide or you would go outside the band limit of 18.168.1
Thanks., I’ll check. It should be at 2.7 like my other bands. But it could be on my AM profile. Very good input and thank you. 73’s0
The TX Filter setting was the problem. It was using the settings from the AM profile and once set to 2.7K, all is well. Thanks to all for your help and thanks to all that have served our Country.0
- 378 Community Topics
- 119 SmartSDR+
- 193 DAX
- 38 Aurora
- 258 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
