DAX Error Splash Screen
Frank Kirschner
Frank Kirschner Member ✭✭
Ever since I upgraded to V3 and then downgraded to V2 of SSDR, I get two DAX error splash screens when I boot the computer. It says "DAX (v2.4.9.196): An unhandled error has occurred: The invocation of the constructor on type 'DAXWPF.MainWindow' that matches the specified binding constraints threw and exception.
"Inner Exception: Could not load file or assembly 'Flex.UiWpfFramework, Version=1.0.1.28766, Culture-neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
"   at DAXWPR.MainWindow...ctor()"
(I tried to upload the image but kept getting an internal server error from the Web site.)
This happens before I try to run any programs, including DAX and SSDR. I re-upgraded to V3, and it still occurs. It's not a disaster, since I just click the OK button to close them, but it's annoying, and indicates that there is something wrong with the software.
Any ideas?
  • N8AUM
    N8AUM Member ✭✭
    edited May 2019
    I've seen this with my 6600 running win7 inumourous times
  • Eric-KE5DTO
    edited May 2019
    Frank,
    This sounds like something you should take a screenshot of and open a helpdesk ticket.
  • Frank Kirschner
    edited May 2019
    OK, thanks. Done. Let's see what advice they have.
