Windows 10 Version 1903 may-updadate
dl9eri/oe9eri
The same procedure as last year ?? It´s comming !!!! may update windows 10 ........
If you want to stop Windows update, put your Ethernet adapter or WiFi adapter in metered mode. It works great!
Jim, K6QE1 -
How? How long will it delay it?0
Or you can use this https://www.oo-software.com/en/shutup10 I use it and works great for me. But use at your own risk.0
Hey, There is nothing wrong with a Windows 10 update that a very large bottle of
single-malt whiskey can't ease.... Just ask the Flex technical support hotline :-)
Neal
Or use Windows 7 and avoid all the Windows 10 problems.0
I had no driver problems with the May cumulative update...actually don't think I've had a problem since last summer's 'feature update'. I've just made sure that SSDR/CAT/DAX are not running when I do the updates. I effectively disable automatic updates by setting the active hours to the maximum and leaving the computer/rig running 24/7. I usually get a warning the a restart is required and will be done outside of active hours, at which point I shut down SSDR and do a manual restart.
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
