Transverter Port Power Output
What is the transverter port output in a 6400M?  When I change the dbm from 1-15,  I get no change in power output from my Ukrainian transverter.
  • Jon_KF2E
    Jon_KF2E Member ✭✭✭
    edited May 2019
    I believe the max output was 0dbm in V2. This changed with V3 and presumably V2.5 to 10dbm.
  • George KF2T
    George KF2T Member ✭✭✭
    edited May 2019
    If you’re not getting additional power out with more power in, the transverter is probably being driven to saturation. You shouldn’t run any more input that recommended by the manufacturer.
    dBm is the power level - decibels relative to a milliwatt. 10 dBm is 10 milliwatts, 13 dBm is 20, etc.
  • Cal  N3CAL
    Cal N3CAL Member ✭✭
    edited May 2019
    Manual says +10dbm max.  Which version of SSDR are you using?
    Cal/N3CAL
