N1MM+ Spectrum Display error with V3
Phil M0VSE
Since upgrading my 6500 to V3, the Spectrum Display in N1MM+ seems to have stopped working... When I attempt to open it, I get the following error from N1MMLogger.exe which is repeated many many times until I close the Spectrum Display window (which doesn't find the radio)
The error reads: "Error: Cat macro command does not contain an even number of hex characters when spaces are removed."
This happens with both SmartSDR 3.0.19 and Maestro.
Has anybody else seen this or is it specific to my setup?
73 Phil M0VSE
73 Phil M0VSE
I just opened spectrum display on n1mm with version 3 and my flex 6500 and it works fine.0
Thanks Dean, it must be my environment then. Strange one!0
One question, is that with the latest version of N1MM+ (1.0.7667.0) released on May 7th?0
Yes same version0
- 324 Community Topics
- 588 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 392 SmartSDR for Mac
- 257 SmartSDR for iOS
- 246 SmartSDR CAT
- 177 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 12 Aurora
- 147 FLEX-8000 Signature Series
- 904 Maestro
- 50 FlexControl
- 862 Genius Products
- 304 Tuner Genius XL
- 114 Antenna Genius
- 272 Shack Infrastructure
- 192 Networking
- 436 Remote Operation (SmartLink)
- 135 Contesting
- 711 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 935 Third-Party Software
