6600M V3 & N1MM+ CW KEYBOARD
Richard Zalewski
Running N1mm+ SO2R and when I use Ctl K each letter is sent twice. Most likely a config issue in N1MM+. Poster there as well.
I have seen many "strange" posts over the years but you come up with some unusual ones. More information please. "each letter is sent twice" - for example, if you type "the" does the cw come out "tthhee" or "thethe" or is each letter mixed together. It sounds like there are two parallel keying processes.
N1MM+ should be set to use winkey through CAT. Is there a second CAT or a different path, e.g. an external keyer?0 -
That's me....the strange one. If I wanted the word "the" it cfomes out tthhee.0
I have not configured for dual transmit. I notice your winkeyer B (COM13) does not flag "slice not present". Just guessing N1MM is sending the word down both ports.
Test by dropping the COM13.0 -
That was it. I guess I was confused on the necessity of having a Winkeyer on each slice. Thanks for the idea.0
- 379 Community Topics
- 636 The Flea Market
- 141 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 930 Genius Products
- 301 Shack Infrastructure
- 462 Remote Operation (SmartLink)
- 793 Peripherals & Station Integration
