ATU triggers two flashing lights
Burt Krain
My 6600 with Maestro Model B triggers a 2 flashing red lights when I press either the ATU or the mic to transmit. It freezes the screen and then disconnects. It does this repeatedly and I cannot figure out what is causing it or how to correct this issue. I have ample power going to the transceiver. Any thoughts on how to fix this issue? Using latest version of 3.0.19.46 software.
Burt,
2 flashes indicates the SW is crashing in the radio, as per the HW Reference Guide,
Error Conditions
Certain hardware and software error conditions cause the radio to stop operating and display an error code by flashing the Power button light as follows:
• One red flash: Fan malfunction
• Two red flashes: Software crash
• Three red flashes: Boot failure
• Four red flashes: Input power over voltage
• Five red flashes: CPU overcurrent
• Six red flashes: Input power under voltage
In the case of a software crash, the error code repeats for about 15 seconds, then the radio will reboot. In the other cases, the error code repeats until the Power button is pressed, then the radio shuts down. An additional press of the Power button is needed to restart the radio.
Too much RF inside the box, have you tried to a good known dummy load?
On the correct antenna port?
If you lower the RF output is there a point that transmitting does not crash the SW?
Could be local RF conditions (Antenna or Common mode RFI ) or a HW issue in the radio..
Let us know what you find,
Dudley
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
