SmartSDR CAT is not launching
Hani - OD5TE
Hello, CAT app is not Launching. SmartSDR and DAX are launching and operating well. Can’t seem to access the CAT interface. Tried re-installing and still no luck. I see the CAT icon on my desktop, but nothing happens when double clicking on it. I am running Windows 10 on Microsoft Surface Tablet. Appreciate any help. Tnx in advance es 73 Hani - OD5TE
Hani, do you see the CAT icon on your taskbar (at the bottom of the screen) when you double-click it (in case the window is positioned 'off-screen')? Another thing to do is right-click on the task bar (after running cat) and select Task Manager. When the Task Manager comes up, click on the Details screen and scroll down and see if you can find CAT in the list of running tasks.
Let us know what you find!
Usually the issue with SmartCAT not starting is the "Virtual Serial Port Service " is not running in the System Services.. Find that service , go to Properties select "Automatic" and start the service manually ... Another way is to to go to the FlexRadioVSP application in Programs and Features, highlight and select "Repair" this will also get it working . Then you can start SmartCAT.
Dudley
Thank you Dudley. Will try and let you know if it works.0
Thank you Neal. Not showing in the task manager or taskbar. Once I click on the CAT icon to run it, I see a spinning wheel for a second and nothing happens. I suspect Dudley’s suggestion could resolve it.0
Hani, what antivirus/antimalware programs are you running?0
Thank you Neal and Dudley, for the swift responses. I followed Dudley’s instructions and CAT is now working. Tnx agn and much appreciated. 73 - Hani0
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
