Single antenna operation
Thanks for the suggestion. Just tried the tuner and it remains in this same state. When both TX and RX are on the same antenna I get no receive. If I switch the TX to Ant 2 the RX works fine.
Sounds like you Split enabled to a ghost slice.. If you close slice A , does a Slice B appear? I can't remember how split worked in version 1.9
Not sure, I will have to check. Wouldn't that condition be wiped out when doing a reset?0
Can you just try plugging your antenna into Ant 2, set RX and TX to Ant2 and see what you see?
I am wondering if you have an ESD diode issue.0 -
Same issue with Ant 2. If I plug in the antenna into the Ant 2 connector then the receiver drops out when I put the TX on Ant 2. Exact same situation either way on both Ant 1 and Ant 2!0
If I close this single slice then I get no slices on the screen. Nothing else appears.
- 379 Community Topics
- 631 The Flea Market
- 122 SmartSDR+
- 193 DAX
- 39 Aurora
- 263 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
