V3 Multiflex 6600M - CW element clipping
On CW, my 6600M with v3 seems to work just like v2, until a second MultiFlex client comes online. Once the second MultiFlex client is online, the first 6600M client starts clipping random elements in the CW sidetone. The second Multiflex client doesn’t have to be doing anything for this to happen.
DETAILS
Using v3.0.19 I’ve found several configurations (details here) where adding a MultiFlex client to my 6600M causes some clipping of CW sidetone elements on the 6600M while operating full break in. The clipping is random, making it difficult to send CW by paddle without errors. The clipping also surfaces in the sidetone of CWX generated code.
The clipping can be seen in the sidetone waveform I recorded below showing four dits in the letter H. The third dit is clipped causing a longer space between it, and the previous dit. Note that the clipping does not happen every time letter H is sent, but occurs randomly in the elements of different characters.
The clipping is significantly more noticeable when you are doing the keying as it interrupts the rhythm between what your fingers are sending and what you hear.
More details here on which configurations were tested, along with other notes.
Is anyone else experiencing this?
John,
I have confirmed this on my 6700. The only difference is I see sidetone jitter even with a single Station enabled. Also, although the sidetone is disturbed, the signal from the radio as monitored on a second receiver seems ok.
73 Ed W2RF
Ed,
Thank you for confirming.
1) What client did you use for the single Station test?
2) I also found the transmitted signal from the radio seems OK.
John, AF3K0 -
Client was SmartSDR v3.0.19. The radio had been running all day in single and multi-client configs. I closed the second client for the test.
73 Ed W2RF0 -
Clipping in the sidetone is not new to V3 (which I have not installed). I noticed it as far back as V2.2.8. See https://community.flexradio.com/flexradio/topics/missing-first-element-in-sidetone
Tim K9WX
Tim,
Sorry I missed your original post! Coincidentally, I ran into this problem during the FL QSO party this past weekend running v2.4.9 and N1MM+ 1.0.7644 on Win10 with paddle plugged into the 6600M.
John AF3K0
- 379 Community Topics
- 631 The Flea Market
- 123 SmartSDR+
- 193 DAX
- 39 Aurora
- 949 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
