Maestro Filteradjustment Slice B wrong
I use Maestro with Flex6400 and installed V3. It works, but slice B has still the same bug with filteradjustment. Slice A: BW Select: Knob inside shift, outside Width - at the push of the button from BW Select executes: Button inside Low shift, outside High shift. That's plausiebel! Slice B: BW Select: Knob inside shift, autside also same schift? at the push of the button from BW Select executes: Button inside High shift, outside same High shift? BW changes only after turning over the slice mark. The starting position is not available any more. Could you please try to fix ist. 73 Tof DJ6ZM
A button setup test has diagnosed a hardware error. I sent in the maestro. Fortunately, we have a service in Germany.
DJ6ZM Tof
I got the maestro back repaired within four days. Great service, fast and competent. Good job.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
