record function in V3 not playng back thru speakers
well here we go again, same question as before, reinstalled V3 to try again, still cant get record audio to play back thru speakers, i did notice that if you keyed mic during playback it appeared to be transmitting audio, according to spectrum on top, just wont play thru speakers so i can check it, checked settings in win 10 and both are set same on both versions, not too excited about V3 with only 6400, but im sure with the higher dollar rigs it quit nice. thanks in advance, not looking for any long thread with arguing!
  • Member ✭✭
    edited May 2020
    since no one else seems to be having this problem, i did find from a froend that the only way you can hear playback in V3 is if you have speakers plugged into back of unit, it wont play through the pc speakers, thanks again
