For V4 I would like to have ........
edited June 2020 in New Ideas
I have no use for V3 so I am looking towards V4
For V4 I would like to have FT8 built into SSDR. It's rapidly becoming the most popular mode on every band especially 160. Incorporating FT8 into SSDR would eliminate the interfacing issues with WSJT-X (need to restart DAX, decoding stops , etc.). Ideally this would tie into JTAlert or perhaps SSDR could have it's own version of JTAlert.
This is a feature I would be willing to pay the upgrade fee for.
2 votes
In Review · Last Updated
Welcome!
«13
  • Member ✭✭
    edited October 2019
    Considering how many people do not like FT8 and how quickly digital mode technology is evolving, I'd be seriously surprised if Flex would consider adding FT8 to SSDR.  This is a feature I'd never pay for.
  • Member ✭✭
    edited April 2019
    FT8 is very ;popular. Most of the action on 160 is FT8 now. That goes for 60 meters as well. 30 meters is another band very active with FT8
  • Member ✭✭✭
    edited July 2019
    As long as it does not use any radio sesources, keeping in mind we are talking thin client here.
    Perhaps just skip V4 features all together and work on many of the oustanding problems we have now. Then go back to working on features.
  • Member ✭✭
    edited April 2019
    How does downloading V3 and letting it sit in a folder without installing it keep you up to date?
  • Member
    edited April 2019
    If/when/before I call for support on a V2 issue I will probably load up V3 to see if that fixes the problem. If it does, then it would be a matter of deciding whether the fix is more important than the loss of functionality.
    Kev
  • Member ✭✭
    edited May 2019
    I think that this point is moot.  My understanding is that the developers of WSJT modes will only allow it to be incorporated into other software if it is on a no-pay basis.  That is why, for example, HRD/Digital Master does not include FT8.  If I'm wrong someone tell me.  Having said that, WSJT-X is so easy to use with the Flex I'm not sure that there would be much point in incorporating it into SDR.
    de Roger W6VZV
  • Member ✭✭
    edited April 2019
    I'll bet RTTY was hated when it was first introduced.
    Pat you'd loose that bet.  RTTY was, and still is popular with hams, even decades ago when electro-mechancial devices were being used.  I consider RTTY a real communications mode, meaning you can carry on a real conversation, not just a brief data exchange.  (Yes, I know JS8Call allows more information.)
    I'll never understand why some people hate FT8 so much.
    Who said hate? Pat what you seem to be missing is, while some enjoy FT8, and that's great, there are others that feel that the FT8 mode is too impersonal, too robotic, too automatic, somewhat mindless, and/or generally boring and repetitious.
    Bottom line, if you enjoy FT8, by all means go forth and exchange call signs and signal reports till your hearts content.  Just know everyone may not see things the way you do.
  • Member, Super Elmer Moderator
    edited June 2020
    Another point of NOT including FT8 encode/decode into SSDR is WSJT-X includes several modes in addition to FT8. With the continued refinement of FT8 (v2 vs v1) it would be difficult for Flex to expend engineering resources to keep up with changes.
    Flex has made it easy to use third party software via DAX and CAT and WSJT-X works extremely well, including Fox/Hound mode so why reinvent the wheel?
  • Member ✭✭
    edited April 2019
    I suppose you could say the same thing about CWX.
    There's a number of third party CW  keyboard coders available.
    Or how about the Quick Record feature? There's lots of ways to do that outside SSDR,
    Just because a function is available via third party applications doesn't mean it wouldn't be nice to incorporate the same functionality in SSDR.
    edited April 2019
    How often does the alphabet change? (CWX)
    Recorder - if you want to do anything but quick record and playback you NEED to use third party software (Contest voice keyer with multiple selections, export recordings to a file)
    The point is the FT8 protocol has changed several times, making older versions not compatible to newer versions. This would require extra engineering time to keep up with the changes. Flex would not release a new version the same day Joe Taylor and crew decide to change F/H mode. Imagine the uproar if a Bouvet Island DXPedition required a new version of FT8 protocol and Flex did not release a new version.
    As Roger mentioned above Joe Taylor has stated there are restrictions to allowing others to use his protocol in other programs. (We had the opportunity to have him as a guest speaker at NJDXA meeting).
    Yes it would be convenient to have an all included but I prefer to leave as-is since it works so well. Using latest Windows 10 OS on an I7 8700k CPU I have not had any DAX dropouts in a long time.
  • Member ✭✭
    edited April 2019
    I doubt that Flex would offer a free core version when they don't even offer a trial period of new releases that they charge for.
    In fact, I mentioned it in a post yesterday and they immediately deleted my post.
  • Member ✭✭
    edited April 2019
    Providing a core release bearing defect repairs at no charge is not the same as offering a trial period for new enhancements.
    The problem with a free trial of new enhancements is that nearly everyone will want to kick the tires, even those not serious about purchasing a license. Supporting all that tire-kicking is consumptive of support and development staff.
  • Member ✭✭
    edited April 2019
    What is the difference between potential buyers reporting bugs verses buyers reporting bugs? A bug regardless of the party reporting it should be fixed
  • Member ✭✭
    edited April 2019
    You are assuming that users evaluating a new feature would only generate support costs if they encounter a defect, which Flex should be happy to correct. Unfortunately, the assumption is false: some users would attempt to assess the feature without having reviewed the documentation, and then contact Support for help -- but never purchase the enhancement because they weren't seriously interested.
    Could marketing collateral - documentation and videos - should enable users to determine whether or not they are interested enough in new functionality to be willing to pay for it. If users are confident that any defects discovered will be promptly corrected at no charge, then there should be no hesitance in purchasing the new feature.
    The frustration with the recent release of v3 has not been "I bought multiFlex thinking it would do X, but it doesn't do so". Users not in interested in multiFlex are frustrated because they must continue to live with uncorrected defects, some of which were corrected in v3. The fact that some 3rd party applications don't work with v3 is another source of user frustration. Both of these sources of frustration can be eliminated.
  • Member ✭✭
    edited April 2019
    Consider this: How many people that take a car for a test drive actually purchase the car? I'd guess a very small percentage. Yet, the dealerships use this in the hopes of attracting actual buyers which they do.
    Somehow with all the time spent with people that do not buy the car they still manage to make a healthy profit. The same applies with Microsoft.
    I'm not going to bore folks with this anymore.
  • Member ✭✭
    edited April 2019
    One can't properly evaluate a car by reading documentation and watching YouTube videos; Tesla recently tried this, and quickly abandoned it. Cars also cost a lot more than new Flex features, and thus can support a higher "cost of sales" -  like salespeople who chaperone test drives.
  • Member ✭✭✭
    edited April 2019
    Most of my suggestions don't get much traction but here is an older one, revisited.
    What is needed is an interface to 3rd party applications that are addressable in two places:
    1) Through a standard format API data block, with content applicable to the particular application being implemented.  This could be any format data
    2) Through a radio interface to a hosted application (such as USB to a local computer that can run the user application)
    With that structure any 3rd party application can communicate from the operating position, remote or local, to the matching application running at the server site.  Think rotator control, decoders, loggers.  All without changing the SSDR in any way, other than creating the interface.
  • Member ✭✭
    edited April 2019
    I agree with Bill, just fix what has been broken for years, then consider adding new features.  One thing I would like to have fixed ASAP is the auto save function for profiles...give us the the option.  73's to all
  • Member ✭✭✭✭
    edited April 2019
    And location (grid square).  Now if only they could add the weather, your job and rig.
  • Member ✭✭
    edited April 2019
    If it's been broken for years in spite of new versions being released then I take that as a clear sign that there are no plans to ever fix it.
  • Member ✭✭✭
    edited April 2019
    I am not a Flex employee
    Even though all versions of software continue to be supported by Flex I suspect soon V2 will become feature frozen if it has not been already.
    In effect being retired....
  • Member ✭✭
    edited April 2019
    Many software organizations make the mistake of prioritizing enhancements over corrections to defects that aren't "showstoppers". But the logic behind correcting all known defects is compelling; organizations can and do improve their software development processes.
    The Flex user community's love-hate reaction to SmartSDR v3 as demonstrated by posts in this forum is a crystal-clear indication that such a change is required.
  • Member ✭✭✭
    edited April 2019
    I also have seen FT8 "change" meaning Joe Taylor is updating it with new modes and features.  I think it would be unlikely that Flex would want to get in that mix with an internal decoder.
    If you are having lots of issues with DAX then something is wrong.  I had a period of instability but it is mostly gone.  I can fire up SSDR and DAX with WSJT-X and it runs all day long without issue.
    Like the others in this comment I doubt flex will re-invent the wheel here.
  • Member ✭✭
    edited April 2019
    From the FlexRadio FAQ:
    "Will there be another release for SmartSDR version 2?"
    "Yes, we will be releasing SmartSDR v2.5 later in 2019. SmartSDR v2.5 will be a maintenance release which will include a number of performance improvements and bug fixes."
    https://www.flexradio.com/faq-smartsdr/
  • Member ✭✭✭
    edited April 2019
    I’d like to see a future version combine the product from several Flex-6000 radio servers together. I’d also wonder if the Maestro and M models could gain an ability to carry onboard software that now has to stand alone? 73 Steve K9ZW
  • Member ✭✭
    edited April 2019
    Reminds of a woman instead of taking a shower cover up the aroma with perfume. Would you paint over a dirty wall or clean it first?
  • Member ✭✭
    edited June 2020
    Another feature on my wish list would be the ability to apply custom skins to SSDR. The 2.3.9 color scheme is pretty boring
