slice master -skimmer woking bu no sports on panadapter
edited April 2019 in SmartSDR for Windows
I am using Slice Master (last version)  with skimmer (2.0) but I cannot see any spots in the panadapter
skimmer is deconding
when I enable in slice master other spotsources I see them in panadapter
Welcome!
  • Member ✭✭✭
    edited April 2019
    Hi Don,
    In the Bandmap group of Slice Master's Settings tab (...) there is an option to 'Show internal spots'
    Do you have that enabled?
    A bit further down the Settings tab in the CW Skimmer group there is another option that controls some minimal filtering on the spots coming from CW Skimmer
    How do you have that one set?
    --Don
  • Member ✭✭
    edited April 2019
    the internal spot was flagged as bitmap
    the CW skimmer  frame  was not flagged, now I did
    but still nothing
  • Member ✭✭✭
    edited April 2019
    Don,
    Send an email to the address you see when Slice Master starts up.  Please include a copy of your Slice Master config folder.  ...just navigate to
        C:Users<your user name>AppDataLocalK1DBO
    then right-click on slice-master and select 'Send toCompressed (zipped) folder'.  This will create a zip file that you can then attach to your email.  The zip will contain logs and config files that should give me a pretty good idea of what's going on.
    --Don
  • Member ✭✭
    edited April 2019
    Done
  • Member ✭✭
    edited April 2019
    Hi
    in this way it works,
  • Member ✭✭✭
    edited April 2019
    Don,
    Thanks for sending your logs and for the screenshots above.  I should have asked earlier which version of SSDR you were running.  From your logs I can see that you are using SSDR v3.  The current version of Slice Master doesnt support v3.  I'll have a new release out in a week or two that will support v3.
    My apologies for the confusion.
    --Don
  • Member ✭✭
    edited April 2019
    CIAO Don Thanks, let me do apologize not to give you the smartsdr version. I will be happy to test new version!
