after ver 3 upgrade 6400m sdr does not control radio, radio works,but band change does not and dis
wayne mckenzie
after ver 3 upgrade 6400m sdr does not control radio, radio works,but band change does not and display on 6400m stays on ?
make sure you do your factory reset after the ugrade.0
holding power on button until shows white ??? did that thanks
what i want to do now is get to the display on the 6400m that shows software ver
then i may try to again load ver 3. total power off power supply disconnected, 6400 conect direct to router and power on does not take me to that display, loads all the way and shows operating screen tnx wayne0 -
If the operating screen is up, go to “Menu/Radio” and execute the Change Version that you will find there (wording may be different, don’t remember exactly). This is how you force an upgrade / downgrade.0
"Switch Version"
thanks that's what i needed, right in front of my face, reload older sw now all is well
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
