after ver 3 upgrade 6400m sdr does not control radio, radio works,but band change does not and dis
wayne mckenzie
after ver 3 upgrade 6400m sdr does not control radio, radio works,but band change does not and display on 6400m stays on ?
make sure you do your factory reset after the ugrade.0
holding power on button until shows white ??? did that thanks
what i want to do now is get to the display on the 6400m that shows software ver
then i may try to again load ver 3. total power off power supply disconnected, 6400 conect direct to router and power on does not take me to that display, loads all the way and shows operating screen tnx wayne0 -
If the operating screen is up, go to “Menu/Radio” and execute the Change Version that you will find there (wording may be different, don’t remember exactly). This is how you force an upgrade / downgrade.0
"Switch Version"
thanks that's what i needed, right in front of my face, reload older sw now all is well
- 337 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 170 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 18 Aurora
- 188 FLEX-8000 Signature Series
- 913 Maestro
- 886 Genius Products
- 320 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 741 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 954 Third-Party Software
