Profile dropdown disappears on PC monitor
Paul Staupe
My 6600M running 2.4.9.115 is great but I've always had a problem when running SmartSDR on my desktop when I switch profiles. The profile dropdown always disappears after a few seconds so I have to quickly change profiles before it disappears and I have to try again. is this a Windows 10 issue or or a configuration error? Thanks.
Do you have some other application running that 'grabs' windows focus, such as N1MM or DXLAB Commander ? Or do you have SSDR Focus helper configured ? ( Settings > Radio )
AL, K0VM
Thanks Al, Yes I always run N1MM in conjunction with SmartSDR and when I shut down N1MM just now, the problem went away. Is there a timer setting on Focus helper?
I discovered the answer to my own question. Yes, there is a variable timer associated with the Focus helper. Problem solved. Thanks Al
- 384 Community Topics
- 648 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
